Results 1 to 7 of 7
    Jul 2014
    new to intense, few m9 questions
    Hi guys,
    I have just recently got an m9 and have a couple of questions.
    There is some creaking from the back end either from the shock bushings or from the linkage. I have read online about replacing the chips on the rear linkage and also using ptfe/plumbers tape on them? I presume this is to be used on the bolts that go into the chips?
    also is there an alternative rear spindle option apart from the standard nut and bolt idea?
    thanks
    Dec 2004
    The creaking can be coming from a couple different places. What year is your M9?
    I had put Teflon tape on the surface of the flip chips, so when they're bolted in and come in contact with the lower link, you eliminate any creaking that may come from there.
    I haven't seen any alternative for the rear axle.
    Intense 951 Evo and Intense Carbine 29
    Jul 2014
    thanks for the reply, ok i'll give that a try with some ptfe tape. do I just put a couple of wraps on the outside of the chips? its a 2013 model.
    Dec 2004
    Since you have a 2013, you also have the newer lower link so no creaking should be coming from there and everything should be staying nice and tight. I put my money on the flip chips for now. You using the Angleset? Those make noise... I know mine does.
    Grease your shoulder bolts too.
    Apr 2005
    Check your spring. Make sure the end of the spring is not resting in the slot on the preload collar.
    Jul 2014
    hi guys, thanks for the replies. last night I took the chips out and cleaned them up and wrapped a couple of layers of ptfe round them and that seems to have sorted out the creaking. just out of interest has anyone used clear silicone on them and how did that work? just thinking that's a bit more weatherproof (especially for here in Scotland and may last longer?
    Dec 2004
    Never thought of silicone... you could just punch out the flip chips if you wanted to change things around. Give it a try.
  1. Replies: 6
    Last Post: 09-18-2013, 01:59 AM
  2. Intense 951 EVO - 275
    By smithrider in forum 27.5
    Last Post: 04-17-2013, 12:33 PM
  3. Replies: 5
    Last Post: 04-05-2013, 11:00 AM
  4. 07 6.6 intense
    By RE50 in forum All Mountain
    Last Post: 05-30-2012, 10:39 AM
  5. Replies: 12
    Last Post: 03-11-2011, 05:35 PM
