Page 2 of 2 FirstFirst 1 2
Results 26 to 43 of 43
  1. #26
    Reputation: Hobine's Avatar
    My Carbine SL Story
    I do think the Carbines are a bit short in the TT for a given size but if your comfortable on it, why worry?
    I'm just shy of 5'8" and ride a small with an 85mm stem and setback seat post.
  2. #27
    Feb 2014
    This is awesome. I'm just getting set to build up my Carbine SL and these posts have been a great reference. Can you detail how you went about stealth routing your dropper. I can see from the pics where the cable goes (down toward the crank) but how did you feed it into the frame? Thru one of the holes where the bottle cage bolt threads are? Drill a separate hole? Something I'm missing. I'd like to put a Thompson dropper on mine and would really like the new stealth dropper they just released.
  3. #28
    Sep 2013
    The latest frames came with stealth route hole and iscg threads. Not sure I've the balls to drill a frame, thanks for thread compliments, good to know it helps.
  4. #29
    Reputation: CarbineSL's Avatar
    Jul 2013
    I'm riding one of the earlier medium size Carbine SL frames. It has neither ISCG tabs nor stealth routing. I put a KS LEV dropper post on my bike a year ago, and it works great.
  5. #30
    Sep 2013
    erm.....Latest update********
    I've lengthened my stem from 70mm to 90mm as the bars felt too close during slow speed turning stuff, also feels better climbing now with a decent stretch. Maybe I should have bought a large frame for my long torso/short arse legs???
    I'm starting to think dropper posts are not for me, I'm just not using it much, maybe I'm not RAD or SICK/POORLY enough??? I'm plenty flexible enough to move around my bike though, so I reckon they're over rated. Would sooner save 1lb of weight and not have the threat of the Reverb breaking again, I realise that's a controversial statement, but that's how I see it. I also feel more stable on descents with the saddle in close proximity, and I can get on the power sooner for seated climbing without having to burn too many matches.
    I've had to change the routing on my rear mech as the cable had started to gouge in to the carbon fibre shock link, not sure whether to ask SAM about that??? Any input buddy???
    I can't help feeling that XX1 would be even better if Shimano had done it, I can't get the gears 100% of the time, maybe it's the wet muddy conditions at the mo or Gripshift being shitty???
    And here's a vid of some Yorkshire riding, it gets more interesting near the end with some nice muddy singletrack. I'm riding more than I ever done at the moment and loving it. I've added music to mask my swearing.
  6. #31
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    Quote Originally Posted by Thelma Viaduct View Post
    So your rear derailleur housing has been rubbing the upper linkage? How do you have it ran on the frame? We generally run the rear derailleur housing down the side of the downtube and then over the front derailleur mount to meet up with the guides on the drive-side seatstay that bring the cable straight to the rear derailleur.
    Sam Wilson
    Things & Stuff Specialist
    Beer Drinker
    Intense Cycles, Inc.
    Sam@Intensecycles.com
  7. #32
    Sep 2013
    I had it running under the top tube to try to keep it looking neater, like you do if using a front mech, some of the earlier pics in the thread should show the routing. The outer had worn away and has left a ~2mm circular gouge in the link.
    I've changed it to downtube routing, I'll keep an eye on the gouge to make sure no cracks develop, but I wouldn't fancy having it fail on some of that fast stuff lol How much do replacement ones cost?
    Cheers, Gaz
  8. #33
    Sep 2013
    Another vid, looking forward to the trails drying out.
  9. #34
    Jul 2013
    I am 170 cm tall, and have a medium Carbine SL frame with Fox Talas 150/120 CTD front shock, which I run as a 150mm except when climbing. I have an Easton Haven 0 degree 100mm stem and Easton EC70XC 685mm bar, which comes out at about 725 mm with ergo grips. I crashed a while ago and scraped a chunk out the Easton bar (right across the logo).
    As I become more experienced, I am taking more aggressive technical lines, and the nicked carbon bar makes me worry about its safety. So I am changing to a 3T Exsero Team bar (red stripe) which is 700 mm wide. The color scheme matches the Carbine SL really well.
    I find my current bar-stem combination kind of slow in tight quarters, and often run off line. I am thinking of changing to a shorter 80mm 3T Arx Team stem in -6 degree position. I bought the bar already, but haven't bought the stem, because I haven't made up my mind how long it should be - alternatively I could also go for a 90 mm. With the stem at -6 degrees, I think this should give me about the same reach, but should hang my butt over the rear wheel as before. Definitely it will lower my center of gravity a bit.
    Anybody with a Carbine SL have any experience making changes like this? Better to ask here first, because everyone knows the frame.
  10. #35
    Sep 2013
    I can't remember if I've said or not??? but I've gone from 70mm -6 deg to 90mm -6 deg and it feels noticeably roomier. Much better in slow speed corners where I felt almost on top of the bars. I might flip the stem next ride too. I'm 176cm, short legs, long body.
    Another vid:
  11. #36
    Sep 2013
    Some more vids, anti-shake switched off on my Sony Action Cam.
    It seems to make a big difference to the footage, not for the better imo.
    Bike has been sweet, going to try the 90mm stem flipped to +6 deg as I've had a bit of lower back ache when riding. If that fails, I'll try the 70mm stem again.
  12. #37
    Reputation: eluv's Avatar
    Apr 2005
    Try riser bars.
  13. #38
    Sep 2013
    Settled on a zero rise 80mm Thomson Stem, seems to be the sweet spot.
    Also put Arch EX rims instead of Crest on my AC Hubs, as I was getting too many buckles with the crests.
    Latest Vid:
    Kind of wishing I'd put the money in to a Ripley now, although the bike is still sweet.
    TV
  14. #39
    Let's Ride
    Reputation: koertle's Avatar
    Hey Thelma,
    I too have a 80mm stem with a zero-offset saddle. It places me perfectly on the bike.
    I'm glad to hear you are enjoying your SL.
  15. #40
    still enjoying your SL? How does it climb, efficient, minimal bobbing, CTD or lockout use?
  16. #41
    Let's Ride
    I'm still enjoying my SL. I recently rode the San Juan trail (all singletrack, 27 miles with 4300 vertical feet of climbing). The bike does everything well. For the rear shock (Fox CTD, trail mode), it does not bob. It feels smooth on the descents and efficient on the climbs. I use the same mode for both climbing and descending (no lever switching).
  17. #42
    Sep 2013
    I've not been on it for a few months, it's had a recent bearing replacement, don't use jet washers. Bought some easton carbon wheels I'll use in the spring. Should really get my pikes serviced too, going to reduce the travel in them to 140mm.
  18. #43
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by koertle View Post
    The SJT is actually Intense riding grounds.
    ----------- __o
    --------- _`\<,_
    BRAAP(>)/ (*)
    ************^^^^¯\_(ツ)_/¯
    http://www.youtube.com/watch?v=qqpcBpSsj1A
  1. 275 Converted Carbine vs. Carbine 275
    By jtforester in forum Intense
    Last Post: 05-28-2014, 03:28 PM
  2. Replies: 8
    Last Post: 09-07-2013, 10:22 AM
  3. Little Story for Ya!
    By subydoo in forum Women's Lounge
    Last Post: 03-26-2013, 05:18 AM
  4. My SS story
    By digital.aaron in forum Singlespeed
    Last Post: 06-24-2011, 08:31 AM
  5. My story
    By halligan in forum General Discussion
    Last Post: 06-04-2011, 09:17 PM
