Results 1 to 14 of 14
    Monarch Plus on carbine
    I always found the CTD shock either too harsh or would blow thru all my travel ....only one ride so far but is feeling pretty damn good. I can tell you that the suppleness at the beginning of the travel is beautiful!
    will spend more time with setting up rebound but ran the shock with 30% sag on the weekend with great success!
    the only downside so far is that I have to use smaller water bottles for short rides
    Reputation: Fatboy Joe's Avatar
    How was it climbing with the Monarch? Thanks
    Sent from my SGH-M919 using Tapatalk
    Mid Drive is the future of e-cargo bikes.
    Did a lot of climbing that day, everything from long steep fire roads to techy rock steps, left it in the middle compression setting and did everything fine. The firmest setting doesn't feel as firm as the CTD shock tho but I would only use that on sections that are really smooth... need to get out and hit some trails with jumps this week. But so far so good
    I am looking to get rid off of my fox rear shock, Could you tell me the size for you monarch? are you able to run both 5.5 and 6' travel?
    Cesar
    Reputation: ozzer's Avatar
    Chuckie, which tune (Medium or Low) did you go with on the Monarch?
    Quote Originally Posted by ozzer View Post
    its a Medium tune
    Reputation: andy_n's Avatar
    Hi Chuckie,
    What size frame is yours and what size bottle do you run? I prefer to run a bottle for Enduros and was worried a Monarch would take up too much space.
    Reputation: neilether's Avatar
    Quote Originally Posted by andy_n View Post
    Hi Chuckie,
    Same question. Don't want to lose the water bottle.
    Can't you just run the monarch the other way to keep water bottle space?
    Hmmm Dad called him a thinker.
    Quote Originally Posted by iscariot View Post
    Even with the shock flipped, it is going to be super tight in there. I have a Large frame, so that should buy me a little bit more real estate.
    Hi Chuckie,
    Sorry about the late response...I am using a small 500ml Elite water Bottle, which fits fine, but previously used the larger camelbak bottles. Larger bottles still fit but they touch the piggyback which may or may not cause concern
    Quote Originally Posted by Chuckie View Post
    What frame size do you have?
    medium
  1. 275 Converted Carbine vs. Carbine 275
    By jtforester in forum Intense
    Last Post: 05-28-2014, 03:28 PM
  2. Replies: 8
    Last Post: 09-07-2013, 10:22 AM
  3. Rockshox difference between Monarch 4.2 & Monarch RT3
    By MontanaTrailJunky in forum Shocks and Suspension
    Last Post: 06-13-2013, 10:19 AM
  4. Yes I know... Monarch RC3 vs Monarch Pluc RC3 vs Vivid air on a NomadC
    By sir_crackien in forum Shocks and Suspension
    Last Post: 02-05-2013, 08:50 AM
  5. RS Monarch, Monarch Plus, Vivid tune diagram
    By Breal604 in forum Shocks and Suspension
    Last Post: 11-05-2011, 05:15 PM
