Results 1 to 7 of 7
    Calm like a Bomb
    Reputation: stunzeed's Avatar
    M9 with Zero Stack HS and Fox 40
    Anyone with a small M9 running a zero stack lower HS with a 40? I am curious if the lower crown hits the frame?
    It does with a zero stack. Any offset like a cane creek will eliminate it though. I've setup both.
    Calm like a Bomb
    Did you run the zero stack anyways? Did it cause any damage?
    Hi
    I have a small and run a cane creek angle set and have it set at 0 and have no issues hitting the frame.
    When I had a 951 with the same set up it did hit the frame on the two bolts of the crown
    hope that helped
    I removed the 40 bumpers an found some sticky bumpers that I placed on the frame. Integrated fork bumpers would be a great addition to the m9.
    Quote Originally Posted by stejam View Post
    Hi
    the angleset is far from a zero stack.
    Quote Originally Posted by deadatbirth View Post
    I didn't state anywhere it was a zero stack I was just giving my finding to help!
  1. Stack-O-Fun.............
    By Smokebikes in forum North & South Carolina
    Last Post: 08-31-2010, 03:38 AM
  2. Replies: 5
    Last Post: 08-21-2010, 06:32 AM
  3. How do I stack up?
    By bfree in forum Nevada
    Last Post: 09-12-2008, 01:04 PM
  4. Headset for Bottlerocket: Zero-stack or non-zero stack?
    By FlippinSweet in forum Transition Bikes
    Last Post: 08-05-2008, 03:25 AM
  5. DH/FR Low Stack HS
    By Axis in forum Downhill - Freeride
    Last Post: 07-13-2005, 04:40 AM
