Page 6 of 7 FirstFirst ... 234567 LastLast
Results 501 to 600 of 611
Thread: M9 Fro
  1. #501
    Reputation: squiby's Avatar
    Quote Originally Posted by squiby View Post
    Does anyone know the actual torque specs from Intense on the new lower pivots?
    I just threw the new link on my old SS1. Betterer system IMO. Used the Santa Cruz torque specs but I don't want to assume they are correct before I take it out for a little abuse.
    Edit: (to keep it on topic) I have another new link to throw on my M9 next.
    I may have spoke too soon.
    When I tested with my flex meter (grabbed the seat and wheel and pulled in opposite directions) it was WAY flexier than with the original link. Almost felt like it had play. I took the cone out and torqued the pivot bolt to about 90 In lb. That has the bike close to the flex I had with the original link.... maybe a little flexier....hard to tell with out a side by side comparison.
    Is that too much preload on the bearings? Or can i go more?
  2. #502
    Quote Originally Posted by downplease View Post
    I've just put the new hardware and bearings in and it feels like the rear end moves side to side at least as much if not more than it did with the old hardware.
    So i'm curious to know how your M9 with the new bolts and bearings feels, does the rear end still move side to side as much as it did before? Also have you compared your updated M9 with one from the factory to see if they feel the same? Does a V10 have this much side to side movement? I really want to know if I put something in wrong or didn't torque it properly or if this movement is normal?
    downplease, did you remedy this issue? Im wondering if the torque specs from Santa Cruz are off for the Intense link or if it was something else.
  3. #503
    edit: just called Intense instead of beating around the bush and guessing
    60 in/lbs for the pivot axle and 125 in/lbs for the cone bolt
  4. #504
    Quote Originally Posted by deadatbirth View Post
    Ha, sniped! I just did the same thing.
    They also said you could apply a little more torque on the pivot axle that is preloading the bearing as long as it is not too notchy, and then check the torque once it beds in. Kinda like a headset. That is what I had already done to get the rear of the SS back to the original state of noodleness. I was hoping the new link would help it in the stiffness department but I don't notice any improvement, even with the shiny new stuff placebo effect. Oh well.
  5. #505
    Reputation: eurospek's Avatar
    Quote Originally Posted by 8664 View Post
    One of the nicest looking DH rigs I've seen posted in a while.
    konahonzo
  6. #506
    thanks!!
    Saturday i change to my long expected fox 40 2012 white!!
    ride.
  7. #507
    got new bearings and link installed finally. pressing them in straight was a bit of a PITA but i figured something out in the end.
    of course after i put everything together, i find out that the new box link's shock mount is a hair bigger then the offset flip chip causing a bunch of play just as i fix one problem, another arises.
    my shock also must has puked up some oil from the last ride too. fvck me
    its hard to tell how much grease you need in the cavities so i just put a ton of Red Devil grease in there
    edit: Intense is sending new off-set flip chips to see if that will solve the problem....crossing my fingers
    heres some pics if anyone was interested
    i used a 5mm nut driver to knock the bearings out
  8. #508
    Reputation: jimarin's Avatar
    Mar 2005
    So is it just with the offset chips and fine with the 9 inch one? Mine is tight but I haven't tried the offset chip with it.
  9. #509
    Quote Originally Posted by jimarin View Post
    the centered flip chips are significantly worse.
  10. #510
    Make sure your shock reducers are pressed in firmly. It may also help if you file them down slightly (to make sure the bolt is clamping the chips tightly in the link!).
  11. #511
    theres nothing wrong with the reducers or bushings. you can see the flip chips moving around in the box link.
    the shock is off to QBP now anyway since the seal head is leaking
  12. #512
    Done.
    ride.
  13. #513
    Reputation: mtbnozpikr's Avatar
    I'm considering picking up a 2012 M9 some time in the near future but would like to know what the changes from 2011-2012 are to the frame. I am assuming that the linkage update is standard now. Also I am assuming it is still available with either the DHX RC4 (Kashima?) or the CCDB. Am I correct? Anything else I should know about?
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  14. #514
    Quote Originally Posted by mtbnozpikr View Post
    yes the link update is now standard.
    i prefer the rc4 over the ccdb. i dont like the the "low and higspeed"
    rebound system!!
    and go with the 2012 fox 40!!!
    cheers and let us see your beast...
    ride.
  15. #515
    Box Link Change
    Tools you need, easy Job. i make it all up side done...
    need a 1/4 tube lube for refuel the bearings..
    and the flip chip for 9.5inch work perfect in the new box link..
    ride.
  16. #516
    I have read that the MRP G2 is the only guide (outside of the SRAM guide which I don't know much about) that will fit the M9. I have an e13 LG1+ and would like to use it if possible. I have seen a few throughout the thread with LG1+ guides on but am wondering if there is anything I should know about installing them.
    2012 Intense M9
    2008 Look 595
  17. #517
    I had an E13 LG1+ 32-36 on my M9, ith saint cranks, fitted ithout problems, perfect fit
  18. #518
    lg1 with descendant crank nondrive 1 spacer drive side 2 spacers under the lg1 the fat spacer + the half from the fat spacer.
    ride.
  19. #519
    Using a SRS with e13 DH cranks and previously saint cranks, both fitted fine. Loads of pictures of M9s on pinkbike.com with all manner of guides if you want to check
    And for what it's worth Im not a massive fan of the CCDB either. Order without a shock and get a BOS Stoy. I have one on my SS1, it's witchcraft.
    Dan
  20. #520
    Great, thanks for the help guys.
    2012 Intense M9
    2008 Look 595
  21. #521
    your welcome! a friend have it in works gold, killa to!!!
    https://www.facebook.com/photo.php?f...type=1&theater
    ride.
  22. #522
    below.
  23. #523
    for me they are wrong, left 1 right 2
    ride.
  24. #524
    zero issues with chain line with this setup on my small cassette. the SRS+ is spaced out with the thinner of the two spacers behind the back plate. on all my other DH bikes thats used RF cranks, ive used this setup....cant remember how my MRP were though.
    RF certainly doesnt make setting up chain line easy by putting a stupid amount of loctite on the shell
  25. #525
    i use E13 Lg1 with truvativ, but never see left 2 spacers!
    sorry but instal, like it is before...
    ride.
  26. #526
    im sorry, no
  27. #527
    deadatbirth: Is it just me or do you have the configuration of the 2.5mm BB spacers wrong?
  28. #528
    It's interesting that Pinkbike wrote in their review about the compatibility of chainguides with the M9. I was just surfing around and ran into a picture of Chris Kovarik with an M9 (CRC build) and clearly there's an e13 LG1+ stocked. Now I just need a frame and I'm good to go.
    2012 Intense M9
    2008 Look 595
  29. #529
    I have a brand new M9 frame and a brand new e13 LG1+ 36-40t guide and the fit is not very good. I think the LG1+ guide's that people are mounting are either modified to fit, or they're using the smaller 32-36t guide. I'm probably going to return the LG1 and try to find an MRP/SRAM guide since they apparently fit better.
  30. #530
    Mar 2005
    Quote Originally Posted by Bnorthro View Post
    I had an LG1 and SRS+ before getting an MRP. To fit the E13's it took way more spacers to get them to clear the frame. With the MRP it was a much better fit. You can make the E13 work but the MRP does fit better.
  31. #531
    yes only the 32-36 fit
    ride.
  32. #532
    I decided to exchange the LG1+ for the MRP G2SL, I've read that it bolts up without any hassle. I can't wait to finally ride this beast!
    I cracked my SOCOM frame at Mammoth in August and I've been waiting on a replacement M9 for about 4 months. It finally came in last week, so stoked to have it, but so irritated at little things like the chainguide not fitting and the fact that it didn't come with an axle (and my LBS didn't have any). Just a few more days...
  33. #533
    I reserved a 2012 M9 frame today. I'm pretty stoked but won't be building until February sometime.
    2012 Intense M9
    2008 Look 595
  34. #534
    Dec 2011
    cool.... i will want to get one....
  35. #535
    i had no problem mounting my SRS+ with only the thin spacer behind the backplate. the Mini G2SL i had fit fine too
  36. #536
    I'm planning on running a 38t guide ring so would obviously need a 36-40t guide to accompany it. My LG1+ would fit the bid but does anybody know what kind of modifications are we talking here? I really don't want to get a G2 if I don't have to.
    2012 Intense M9
    2008 Look 595
  37. #537
    With my fork arriving tomorrow I will have everything to complete my build minus the frame... I guess it's good to be excited about something.
    2012 Intense M9
    2008 Look 595
  38. #538
    I think you'd have to grind a bit of the back plate off where it crosses the seatstay on the swingarm. I didn't take any pictures when I was trying to mount it, but I'm sure you could get it to work with a bit of dremeling.
  39. #539
    Here are a few shots I just took of my bike with the MRP G2SL. You can see the back of the MRP guide would hit the triangle if it were any larger. The e13 guide is taller and wider there, and I think rotated back more. I'm running 2 washers as spacers and the chainline looks pretty good. Hope that helps
    Attached Thumbnails Attached Thumbnails M9 Fro-imageuploadedbytapatalk1326762640.246823.jpg
  40. #540
    Thank you very much. I think that helps a lot. I will have everything to put the bike together tomorrow (minus the frame and the shifter cable/housing) and I think that I will end up just waiting until I actually start the build. I have been told by Intense that it should work but might need to be spaced more.
    My goal is to have everything ready to go so when the frame arrives in February I can build from start to finish in one shot. That said, if the e13 is too much trouble, I can get an MRP pretty quickly. Thanks again.
    2012 Intense M9
    2008 Look 595
  41. #541
    No worries, good luck on the build. I'm still waiting on a rear axle so I haven't had a chance to ride it yet. Soon hopefully...
  42. #542
    The fork came in today so all I'm waiting on are the frame and headset which should be here in February. Now I guess the trick is to be patient until it gets here...
    2012 Intense M9
    2008 Look 595
  43. #543
    selling my DB coil and just ordered a DB Air for my bike. should be shipped on 2/15.
  44. #544
    there are very nice bike parts..
    look this until your frame come inn... what color you order?
    Matt Beer 2011 Video Video - Pinkbike.com
    ride.
  45. #545
    is the rear axle not incl.??
    ride.
  46. #546
    Thanks for the link to the video. She's going to be red.
    2012 Intense M9
    2008 Look 595
  47. #547
    red is so nice!
    ride.
  48. #548
    It wasn't on mine, but mine was a warranty replacement for a cracked SOCOM. I know that the new frame at my LBS included an axle. A buddy gave me a steel one he had lying around, but the M9 dropouts are really thick and the axle only engages a few threads per side so I'm not real confident running it like that.
  49. #549
    ok., my original m9 axle without washer is excellent!
    ride.
  50. #550
    Some changes since last time:
    Ti spring from the classifieds
    e13 cranks 170mm in the CRC sale
    Easton Havoc carbon bars
    SDG Ti Fly saddle (sale)
    ODI Troy Lee grips (sale)
    I've a got Bos Stoy from the classifieds going on this weekend so no more CCDB. A great shock but a proper PITA.
  51. #551
    How are your springs rates compared to the recommendations in the manual? I haven't had a chance to ride yet, but I'm curious. I'm about 230lbs and I'll be running a 500 or 550 lb spring per the CCDB table.
  52. #552
    im about 230 geared up and running a 450Ti for the 8.5-9" setting. sag is spot on
  53. #553
    Sweet, thanks for the info. I've got a 450 as well I can try. Good to know.
  54. #554
    I can't complain but as it turns out my frame showed up about 2-3 weeks early and will be delivered to me Tuesday. I'll post pictures when I finish the build.
    2012 Intense M9
    2008 Look 595
  55. #555
    I have a 550lb x 3.00 ti spring NEW for cheap just instant message.
  56. #556
    A large red M9 arrived at my place this afternoon. It is absolutely beautiful and I can say I am extremely impressed at the quality and workmanship of the frame. It is just about built up but I will post pictures after I get my brake lines replaced.
    2012 Intense M9
    2008 Look 595
  57. #557
    Nice! Congratulations. Curious to see how you get the e13 to fit.
  58. #558
    Thanks a bunch. The e13 fit very well without any problems or modifications. The upper guide is close to the rear triangle but doesn't touch at all. When I post pictures I'll post some of the spacing as well as the clearance.
    2012 Intense M9
    2008 Look 595
  59. #559
    Broken but on the mend
    Reputation: mzorich's Avatar
    Mar 2011
    is anyone running a double barrel air on their m9 yet. i am buying a m9 in 2 months and want to know if i should just get the bike with one on it since it is 150 bucks to upgrade in stead of getting it with the coil then going air later
  60. #560
    Many are happy with the CCDB but I could not get along with it, Saying that, it might be perfect for you..? Take your time, do some research and look into your options. There are plenty out there.
  61. #561
    Quote Originally Posted by mzorich View Post
    no one is yet. they just started shipping OEM shocks and customer shocks are shipping on the 15th....i should hopefully have mine soon after. i didnt think Intense was offering it as part of their upgrade yet.
  62. #562
    Mar 2011
    fanatik is offering it as an upgrade
  63. #563
    I don't see it listed on their website. Do you have to talk to them to get the swap?
    2012 Intense M9
    2008 Look 595
  64. #564
  65. #565
    Mar 2011
    i don't think they are actually selling it yet but if you go and build a complete m9 with the fanatik builder its and option
  66. #566
    As promised, here are a few pictures of my 36-40t e13 LG1+ fitted to the M9 frame without modification. I have two thicker black washers sandwiching a thin brass spacer for a total spacing of about 5mm. I have it tilted forward and am about 3-4mm away from the linkage.
    2012 Intense M9
    2008 Look 595
  67. #567
    Looking good, fit better than I thought it would.
  68. #568
    Thanks, I'll post pictures of the full build when I get the brake lines replaced probably (hopefully) next weekend. I've run both the MRP G2 and e13 LG1+ and think that they are just about equal products but I like the looks of the e13 better so I was very pleased when it fit. The fact that I didn't have to drop another $130 or so for the G2 SL wasn't too bad either...
    2012 Intense M9
    2008 Look 595
  69. #569
    Reputation: Intenseman's Avatar
    Mine....before Re-paint
    'Tentense...or Intenseman
  70. #570
    Reputation: goog's Avatar
    Quote Originally Posted by Intenseman View Post
    I wish I was your trash man
  71. #571
  72. #572
    I just got the brake lines replaced and picked it up this morning. A big thanks to Brian at Wrench Science. Can't wait to get out and ride.
    2012 Intense M9
    2008 Look 595
  73. #573
    Not sure what happened there but my two pictures were put side by side so I deleted the one to eliminate the majority of the side-scroll. Here is is:
    2012 Intense M9
    2008 Look 595
  74. #574
    <object width='500' height='281'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/245964/l/' /><embed src='http://www.pinkbike.com/v/245964/l/' type='application/x-shockwave-flash' width='500' height='281' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/245964/">Sunday ride</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    ride.
  75. #575
    @ mtbnozpikr
    sick ride!!
    ride.
  76. #576
    Reputation: ozzer's Avatar
    Out with team Yellow, in with the red for 2012 and beyond. I slapped the Deemax on in preparation for the Formula One season. Guess who's team/manufacturer I'm rooting for..
    Some sales guy (lol) at Intense has my only other Vivid Air but otherwise, it'd be on my bike.
    Currently at 39lbs right now and hella fun to throw around .
  77. #577
    sick ride!!
    ride.
  78. #578
    after several rides on the DB Air, i have to say that im really impressed with the shock. its on par, if not better then my coil DB. i am having to run the shock in the lowest progression setting but its been taking all the abuse ive been throwing at it.
  79. #579
    is there a big difrenz between the midle and upper "linear" progression setting?
    ride.
  80. #580
    Reputation: arthuar's Avatar
    I don't know if I can call it big, but you can note it definetely.
    The bike, especially on rough and hard tracks, is more reactive; if you got used to pump it before the obstacle, it's better a lot.
    It depends on you, but, for my likes I prefer it less linear and more progressive (.. reactiveness helps!)
    Have a good time with this bike, it's sooo...good
  81. #581
    Quote Originally Posted by arthuar View Post
    ahh, if it is in the midle progressive.. hole you can push bump it before a jump...
    and in the upper hole is more plow..
    yes i wil have a nice time with this beast...
    9 or 9.5 travel?
    ride.
  82. #582
    Quote Originally Posted by ozzer View Post
    ride update.. as seen on Vital. New Dorado works great so far. The black E13 bashguard is 0.14 sec faster than the white.
    2013 Intense Bombers M9 - ozzer's Bike Check - Vital MTB
    I miss riding the M9. Been spending lots of time on the Carbine lately.
  83. #583
    Reputation: CoyoteRun's Avatar
    Like it you have the M9 stickers on the brake lever!
    How do you like the Dorado?
    Thanks,
  84. #584
    @ozzer,very nice with Dorado, what you make to the downtube? i ride the dorade now 7mt, can't be happier!!!
    my frame is on the way
    ride.
  85. #585
    How many M9's have you owned up to now? What happened to your Doberman Stella?
    2012 Intense M9
    2008 Look 595
  86. #586
    i like to ride diverse bikes.
    ride.
  87. #587
    Sounds good to me. What shock and fork are you going to have on your latest iteration?
    2012 Intense M9
    2008 Look 595
  88. #588
    check this
    Life is beautiful
    fork dorado!
    ride.
  89. #589
    The down tube protection is the same downtube protection used on the Carbine -just slightly cutout to fit.
    (Jeff, better stock up and create a SKU to sell this stuff).
    I thought it was a neat novelty to have as a first line of defense for the highly battered spot of the frame.
    I really like my Dorado...so far. It's all just a matter of how reliable it's going to be from this point forward. So far, I LIKE it and two of the guys in our team have switched as well after taking my Dorado for a run or two.
  90. #590
    @ozzer
    thanks.
    is there a big difference between the boxxer and dorado... weigh,t small bumps feedback, fork rake ..?
    ride.
  91. #591
    Reputation: trojans1993's Avatar
    LizardSkins makes a "Carbon Leather" version that feels pretty tough and fits perfect on the M9 with just a couple tiny notches for the cable stays.
  92. #592
    super nice!
    ride.
  93. #593
  94. #594
    my fluo baby
    boom shakalaka
    16.32Kg
    ride.
  95. #595
    my fluo baby 16.32Kg
    Nice!
    2012 Intense M9
    2008 Look 595
  96. #596
    Dang, looking at all these slick rigs makes me want to ride - the 9 is getting some dirt action this weekend for sure. Nice job on your builds guys!
  97. #597
    that is a large size?
    ride.
  98. #598
    my medium have a 13.5cm headtube like a large frame but frame is a medium any idea why?
    EDIT:
    since mid 12" the medium hafe the same HT like the Large 13.4mm.
    ride.
  99. #599
    @ 8664, I am pretty sure Intense has always used the same head tube length for medium and large M9s. That goes for most of their frames with full 1.5" head tubes.
  100. #600
    Cool,
    ride.
