Page 4 of 7 FirstFirst 1234567 LastLast
Results 301 to 400 of 611
Thread: M9 Fro
  1. #301
    Reputation: boogenman's Avatar
    His ass area is usually tender
  2. #302
    Now that there are a few of you that have either built an M9 or many of you that considering to do so, I would like to here your thoughts on a couple things........
    The bottom bracket is higher than most DH frames, will/or does this still allow it to feel/carve a turn like the M6 or 951? (I know this has been asked, but I haven't read a reply from a owner)
    What about the reach, does it feel like an M6 or longer like the 951?
    In the G3 forward setting how close is a 2.50 tire to the lower swing link? (pictures)
    I have seen pictures of Kovarik's black M9 and I am wondering what angle set cup is used(- .5 ?) and what travel setting it is set at (9.5 ?)
    thanks..........
  3. #303
    Quote Originally Posted by N-Dawg
    thanks..........
    The bottom bracket isn't higher than "most DH frames." My bottom bracket height is 13.75" in the middle G3, 0* Cane Creek angle set cup, and fox 40 with the crowns set to 8.25." If you installed a boxxer and lowered the crowns you could get the BB height even lower. I have owned two M6's and have ridden a few 951's. The reach on the M9 is longer than both of those bikes (all the bikes I owned and tested were mediums.) I run 2.5" maxxis minion 3C tires mounted on Mavic EX721's and in the short G3 position there is an ample amount of tire clearance. A profile picture showing the tire clearance is very deceiving. It makes the tire look much closer than it really is. If you look down behind the seat you will see there is enough clearance (if that makes sense.) I don't have any pictures of the tire clearance. Lastly, I have no idea which angle set cups CK runs. I would venture to guess he might chance the geo's on his bike according to the race course. But then again, he isn't very technical when it comes to his suspension and geometry compared to Matti Lehikoinen.
  4. #304
    Decided on black wheels in the end, hopefully i wil lget it built within the next 2 weeks
  5. #305
    Lord of the Chainrings
    Reputation: Mudd's Avatar
    Apr 2002
    Congrats!
    Quote Originally Posted by Christiaan
    "Hesitation is the Mother of Failure!"
    ~~ 951 for Dirt & Roadster for Asphalt ~~
  6. #306
    Reputation: Descent 5.75's Avatar
    Do like the black rims over the white also. Have been looking forward to seeing the build when it was finished. Short of the fork and wheels, same route Im going. Only 4 more days.
  7. #307
    Reputation: quickneonrt's Avatar
    do the dropout washers go on the inside or outside?
    2014 Santa Cruz Solo c.
    Moving on to better things
  8. #308
    Riding dirt since 1970
    Reputation: lifer's Avatar
    Quote Originally Posted by quickneonrt
    inside
    Med. Nomad C for sale
  9. #309
    Thanks Dwdrums00 for the info you posted,
    I would like to here about the ride characteristics too if any of you have had a chance to ride it yet.
  10. #310
    Quote Originally Posted by lifer
    inside
    How heavy are your M-9s building up?
    Mine is a small and it's 41.5lbs with steel spring. It will lose a little weight when I get a Ti spring and the Avalanche cart for my boxxer but it probably will stil be around 41lb
  11. #311
    Mine medium came in at 37.98lbs with a fox 40, ccdb, saints and 3c maxxis minions.
  12. #312
    My Large came in at 38.5 with Boxxer Worlds, ccdb and Schwalbe Muddy Marys. Will shape off some .5 changing the tyres as they are crappy anyways...
  13. #313
    Reputation: sikocycles's Avatar
    Have my pedals, i9s and Dorado coming
  14. #314
    Reputation: marci0's Avatar
    I have a problem ..
    My weight 77kg ( ReadytoRide )
    9.5" / Middle Front Setting
    Now I have 450ti spring of canecreek inherited from the 951, too hard for my weight.
    My doubt is whether that of 350 is too soft ? Risk in big drops? the 400 might be too hard if I decide to change the travel in 8.5/9 ... ( according to the instructions of the document CCDB/M9 )
    Especially not clear to me the question of preload of 2 / 4 spring turns!!! :O FOUR TURNS ? I never pre-loaded a spring more than two turns maximum!
    What could be the most appropriate spring to my weight which provides a flow-ride and also not to blow up the double barrel if every time I make a few big jump!
    Help ME!
    However, comparing the curves of compression should be at least two different springs if you wanted to change the parameters.
  15. #315
    Finally a better picture of mine...
  16. #316
    Quote Originally Posted by Intenseman
    I will be using the same guide and cranks.
    What spacers did you use on the guide and cranks. Thanks for the help.
  17. #317
    Reputation: Intenseman's Avatar
    Quote Originally Posted by sikocycles
    RTW always supervises my baby
    'Tentense...or Intenseman
  18. #318
    Is your King BB a 83mm or did you just remove the plastic spacer?
  19. #319
    Where's the chair lift?
    Reputation: IntenseRdr's Avatar
    New question here.
    Cool Pedals! Never heard of the brand. Do they have a website?
    Pimping out on the ride no doubt! Look forward to seeing the finished product!
  20. #320
    The pedals are Twenty6 with my name engraved in them.
  21. #321
    ... and if we just ...
    Ahhh!!! Ok, now that makes sense. LOL A couple of us were looking at them saying they gotta be TWENTY6 or they are being copied by someone. LOL Thanks man!
    Nice work engraving!
  22. #322
    Quote Originally Posted by marci0
    I have a problem ..
    Help ME!
    Cane Creek Cycling Components ---> Marco
    Malcolm says... "A 350lb spring is where I would start for the 8.5 and 9” mode. The leverage curve is not as progressive as the 951, a 400lb would be used in the 9.5 mode. Note a spring is often the most overlooked adjustment on a shock and you are swapping between leverage ratios and curves with the M9’s multiple settings. We like preload on the spring, true most allow only 2 turns. We can run 1 - 5 turns of preload depending on what is needed so 2 - 4 turns of pre load are ok."
  23. #323
    Finally got my ad up: http://classifieds.mtbr.com/showprod...?product=60062
    Sucks I never got to ride it
  24. #324
    Reputation: mtbnozpikr's Avatar
    I've got to say that's an awesome work station you've got there.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  25. #325
  26. #326
    [/QUOTE]
  27. #327
    My first Intense
    " width="549">
  28. #328
    Hey,
    I see you are using Stans Flow rims, are they strong enough to handle the abuse of DH?
    Brett
  29. #329
    Quote Originally Posted by brett ferguson
    Hey,
    Brett
    Well, my first front rim only lasted 2 runs, but i think that was due to a badly laced wheel. They do take some getting used to, I was on EX823 rims before, and never gave it a second thought,but with the flows I was a bit more carefull. they are light, and can take some abuse, but maybe better for just race wheels
  30. #330
    Reputation: ozzer's Avatar
    some sticky note yellow M9s in parking lot action
    love love love love love this bike.
  31. #331
    Faster the Better!
    Apr 2005
    Smile
    So those running saint cranks and the Mrp G2 guide...What spacers are you using...?? Buliding my M9...Should be ready by the weekend..
    SC
  32. #332
  33. #333
    Apr 2002
    Trade for a 951 frame?
  34. #334
    Reputation: FanatikBike.com's Avatar
    Dec 2008
    Apple green and team green M9 frames!
    Just got a couple green M9 frames...apple green and team green! Gotta say the apple green looks incredible!
  35. #335
    that apple green is sweet. i bet that can am yellow would look pretty awesome too
  36. #336
    Quote Originally Posted by Mudd
    No, but I'll sell it to you for $2640. shipped, with the Ti spring of your choice:
  37. #337
    Faster the Better!
    Apr 2005
    Here is mine...Couple more changes coming but couldnt wait to build it up...New Codes and some Black Lowers for the Forty......Thanks FanatiK Bike...You guys ROCK!!!!
    Eric
  38. #338
    Eric, If you dont mind me asking. Where is Seattle/WA are you going to ride that thing? Lived up there up until the last 2 years and until that point, only had a HT Rocky Mountain w 100mm fork. Didnt really see a need for much more. But then the only few places I was riding were around Tiger. Looking forward to getting back up to Whistler one day with the M9, but not really in the cards for now.
  39. #339
    Faster the Better!
    Apr 2005
    Quote Originally Posted by Descent 5.75
    I have a season Pass at Whistler every year. Port Angeles, Stevens Pass (hopefully this summer) The Exits, Duthie, North Shore, BlackRock, Mt Hood..Going to Lake Tahoe for a few weeks...Sun Peaks for a week...Bellingham...Just a few places....
  40. #340
    Dec 2008
    Quote Originally Posted by Seattlechronic
    Eric
    Looks awesome! Enjoy!
  41. #341
    Nice.
    If you havent already set up your CCDB. Got these settings from Malcolm at Cane Creek as the settings they used when originally testing the M9. Just a starting point, but hopefully they help ...
    HSC 1.5 - 1.75 turns
    LSC 13 - 15 clicks
    HSR 1.5 - 2.0 turns
    LSR 12 - 17 clicks
  42. #342
    M9 FRO for Sale
  43. #343
    how much without the shock and ti spring?
  44. #344
    I'm guessing the shock/spring would bring about $250. Sound about right?
  45. #345
    2011 M9 FRO for Sale
    Did some checking, and the '11 RC4 is $585.00 w steel spring at Jenson, and it's backordered. Shouldn't be too hard to sell on its' own, so I'll do the frame for $2300. shipped. Noted in ad: http://classifieds.mtbr.com/showprod...?product=60062
    Thanks for the interest.
  46. #346
    Dec 2008
    Another custom color! White M9 goodness...
  47. #347
    Reputation: hacke242's Avatar
    Nov 2007
  48. #348
    Shut up and RIDE!
    Reputation: doc-ock's Avatar
    Jan 2005
    i'm 170lbs all geared up, is a 400lb spring rate correct for my weight? i would want to use the middle setting. i use an rc4 shock. i'm planning to buy a 350lb renton ti spring. would it be more appropriate for my weight? thanks in advance
    Santa Cruz Nomad Carbon
    Intense M9
  49. #349
    Quote Originally Posted by hacke242
    That orange looks great. Makes most of the other colors look boring.
  50. #350
    Almost done, just need to fit the Formula The One brakes
  51. #351
    16.58kg according to my scale, with unciut hoses and mudflap
  52. #352
    Nice, wish I could find a place to pick up the Nailer. Neither Six Pack nor Superstar ship to the US.
  53. #353
    Great bikes, Guys. Paypal is now an option on this new Med. Raw:
    http://classifieds.mtbr.com/showprod...=61813&cat=500
  54. #354
    M9 Complete?
    Anyone know if and when a complete m9 will be released?
  55. #355
    Quote Originally Posted by wendall85
    I doubt a complete will be released from the factory but Fanatik sells a complete M9.
    2012 Intense M9
    2008 Look 595
  56. #356
    couple of new parts...Formula The Ones, WTB Silverado Ti saddle, KMC X9sl
    me and a buddy's candy apple green. the green is awesome in person
  57. #357
    I spot an Avalanche cartridge.
  58. #358
    Quote Originally Posted by Tree
    good eye. i took it for a ride and it is night and day b/w the stock Boxxer damping.
  59. #359
    M9 FRO for Sale
    Anyone want a killer deal on a new 2011Med Raw? Just dropped the price another 10%...
  60. #360
    any idea how much grease should be injected into the nipples?
  61. #361
    Nov 2007
    " width="549">
  62. #362
    whooo is that copper
  63. #363
    Nov 2007
    nope. its tangerine orange.
  64. #364
    nice!
    ride.
  65. #365
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    Looks great!
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
  66. #366
    Nice orange!
  67. #367
    Nov 2007
    thx!
  68. #368
    That's just rude. I like it!
  69. #369
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    Wow, that orange/white combo looks stunning!
  70. #370
    The Mo
  71. #371
    Reputation: eurospek's Avatar
    Nicest orange themed one I've seen yet. Do want.
    konahonzo
  72. #372
    The M9 complete is available from intense. Same kit as the 951
  73. #373
    Quote Originally Posted by deadatbirth
    Enough to purge all of the old grease
  74. #374
    For SALE, Custom Decals for M9 FRO. :-)
    Uploaded with ImageShack.us
  75. #375
    I like it raw - my new M9 FRO
    My local LBS Sierra Cycles finished my M9 yesterday. Thanks guys!
    http://www.sierracyclesny.com
    Drewski
    “The Beatings will Continue Until Morale Improves”
  76. #376
    Apr 2002
    Nice! Congrats drewski!
  77. #377
    That orange & white color scheme is so clean. Well done.
  78. #378
    Just in case anyone's shopping for a new M9 frame, I just dropped the price on this med. raw again
    http://classifieds.mtbr.com/showprod...for-sale&cat=7
  79. #379
    Quote Originally Posted by marci0 View Post
    More info please...
  80. #380
    this BABY make my Happy,M9 what else...
    ride.
  81. #381
    Finally got a chance to ride it! mud fest, but it rides GREAT
  82. #382
    Good job!
    LOL Nicely Done Man!!! How was it? Was as good for you as it was for the bike?
    Cant wait to get a ride on mine!!
  83. #383
    @christiaan
    a other one without angelset??
    ride.
  84. #384
    Quote Originally Posted by 8664 View Post
    @christiaan
    No, this still has an angleset, but with 0 degree cups, i am waiting on another chris king i4 inset
  85. #385
    Glad your back on the stik, C. Looking forward to that myself.
  86. #386
    Quote Originally Posted by lifer View Post
    Jup, can ride for half a day before the power in my hand gets to low to grip the bars, so getting there
  87. #387
    humber river advocate
    here's mine
    bought from
    http://www.cycle-solutions.com/ ask for simon
    broadcasting from
    "the vinyl basement"
    build trail!
  88. #388
    very nice!
    ride.
  89. #389
    Good job!
    Quote Originally Posted by singlesprocket View Post
    here's mine
    bought from
    Nice Job!!! Congrats on the build man!
  90. #390
    getting it dirty
    did a couple mods since this pic was taken
    broadcasting from
    build trail!
  91. #391
    nice ride!!
    ride.
  92. #392
    Reputation: Rusty_Shackleferd's Avatar
    Do the M9's tend to run a little bigger than most other DH bikes? I was all set to order a medium but after reading a few comments from people on the intrwebz I'm wondering if I should pick up a small. I'm 5'7" and generally like a medium frame so I can keep everything tight in the twists and turns.
  93. #393
    Quote Originally Posted by Rusty_Shackleferd View Post
    I normally ride a medium frames and im 5' 9" but I ride a small M9
  94. #394
    Thanks for the info
  95. #395
    Custom Decals, new style for my *****.
  96. #396
    super sick decals!!!
    ride.
  97. #397
    Love it !
  98. #398
    @ Marcio
    how you like it in the highest progression?
    ride.
  99. #399
    very responsive in curves,I keep the setting at the rear into the lower hole with the minimum wheel travel, now I'm feeling very well
  100. #400
    One of the sickest bikes I've seen in a while. Everything just flows so well together.
    Quick question, what Odi blue endcaps are those? Never seen blue, only blue lock rings which I have ATM.
    konahonzo
