Page 23 of 25 FirstFirst ... 13 19 20 21 22 23 24 25 LastLast
Results 551 to 575 of 611
Thread: M9 Fro
  1. #551
    How are your springs rates compared to the recommendations in the manual? I haven't had a chance to ride yet, but I'm curious. I'm about 230lbs and I'll be running a 500 or 550 lb spring per the CCDB table.
  2. #552
    im about 230 geared up and running a 450Ti for the 8.5-9" setting. sag is spot on
  3. #553
    Sweet, thanks for the info. I've got a 450 as well I can try. Good to know.
  4. #554
    Reputation: mtbnozpikr's Avatar
    I can't complain but as it turns out my frame showed up about 2-3 weeks early and will be delivered to me Tuesday. I'll post pictures when I finish the build.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  5. #555
    Quote Originally Posted by Bnorthro View Post
    I have a 550lb x 3.00 ti spring NEW for cheap just instant message.
  6. #556
    A large red M9 arrived at my place this afternoon. It is absolutely beautiful and I can say I am extremely impressed at the quality and workmanship of the frame. It is just about built up but I will post pictures after I get my brake lines replaced.
    2012 Intense M9
    2008 Look 595
  7. #557
    Nice! Congratulations. Curious to see how you get the e13 to fit.
  8. #558
    Thanks a bunch. The e13 fit very well without any problems or modifications. The upper guide is close to the rear triangle but doesn't touch at all. When I post pictures I'll post some of the spacing as well as the clearance.
    2012 Intense M9
    2008 Look 595
  9. #559
    Reputation: mzorich's Avatar
    Mar 2011
    is anyone running a double barrel air on their m9 yet. i am buying a m9 in 2 months and want to know if i should just get the bike with one on it since it is 150 bucks to upgrade in stead of getting it with the coil then going air later
  10. #560
    Many are happy with the CCDB but I could not get along with it, Saying that, it might be perfect for you..? Take your time, do some research and look into your options. There are plenty out there.
  11. #561
    Quote Originally Posted by mzorich View Post
    no one is yet. they just started shipping OEM shocks and customer shocks are shipping on the 15th....i should hopefully have mine soon after. i didnt think Intense was offering it as part of their upgrade yet.
  12. #562
    Mar 2011
    fanatik is offering it as an upgrade
  13. #563
    I don't see it listed on their website. Do you have to talk to them to get the swap?
    2012 Intense M9
    2008 Look 595
  14. #564
  15. #565
    Mar 2011
    i don't think they are actually selling it yet but if you go and build a complete m9 with the fanatik builder its and option
  16. #566
    As promised, here are a few pictures of my 36-40t e13 LG1+ fitted to the M9 frame without modification. I have two thicker black washers sandwiching a thin brass spacer for a total spacing of about 5mm. I have it tilted forward and am about 3-4mm away from the linkage.
    2012 Intense M9
    2008 Look 595
  17. #567
    Looking good, fit better than I thought it would.
  18. #568
    Thanks, I'll post pictures of the full build when I get the brake lines replaced probably (hopefully) next weekend. I've run both the MRP G2 and e13 LG1+ and think that they are just about equal products but I like the looks of the e13 better so I was very pleased when it fit. The fact that I didn't have to drop another $130 or so for the G2 SL wasn't too bad either...
    2012 Intense M9
    2008 Look 595
  19. #569
    Reputation: Intenseman's Avatar
    Mine....before Re-paint
    'Tentense...or Intenseman
  20. #570
    Reputation: goog's Avatar
    Quote Originally Posted by Intenseman View Post
    I wish I was your trash man
  21. #571
  22. #572
    I just got the brake lines replaced and picked it up this morning. A big thanks to Brian at Wrench Science. Can't wait to get out and ride.
    2012 Intense M9
    2008 Look 595
  23. #573
    Not sure what happened there but my two pictures were put side by side so I deleted the one to eliminate the majority of the side-scroll. Here is is:
    2012 Intense M9
    2008 Look 595
  24. #574
    <object width='500' height='281'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/245964/l/' /><embed src='http://www.pinkbike.com/v/245964/l/' type='application/x-shockwave-flash' width='500' height='281' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/245964/">Sunday ride</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    ride.
  25. #575
    @ mtbnozpikr
    sick ride!!
    ride.
