Page 22 of 25 FirstFirst ... 12 18 19 20 21 22 23 24 25 LastLast
Results 526 to 550 of 611
Thread: M9 Fro
  1. #526
    Quote Originally Posted by 8664 View Post
    sorry but instal, like it is before...
    im sorry, no
  2. #527
    deadatbirth: Is it just me or do you have the configuration of the 2.5mm BB spacers wrong?
  3. #528
    Reputation: mtbnozpikr's Avatar
    It's interesting that Pinkbike wrote in their review about the compatibility of chainguides with the M9. I was just surfing around and ran into a picture of Chris Kovarik with an M9 (CRC build) and clearly there's an e13 LG1+ stocked. Now I just need a frame and I'm good to go.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  4. #529
    I have a brand new M9 frame and a brand new e13 LG1+ 36-40t guide and the fit is not very good. I think the LG1+ guide's that people are mounting are either modified to fit, or they're using the smaller 32-36t guide. I'm probably going to return the LG1 and try to find an MRP/SRAM guide since they apparently fit better.
  5. #530
    Reputation: jimarin's Avatar
    Mar 2005
    Quote Originally Posted by Bnorthro View Post
    I had an LG1 and SRS+ before getting an MRP. To fit the E13's it took way more spacers to get them to clear the frame. With the MRP it was a much better fit. You can make the E13 work but the MRP does fit better.
  6. #531
    yes only the 32-36 fit
    lg1 with descendant crank nondrive 1 spacer drive side 2 spacers under the lg1 the fat spacer + the half from the fat spacer.
    ride.
  7. #532
    I decided to exchange the LG1+ for the MRP G2SL, I've read that it bolts up without any hassle. I can't wait to finally ride this beast!
    I cracked my SOCOM frame at Mammoth in August and I've been waiting on a replacement M9 for about 4 months. It finally came in last week, so stoked to have it, but so irritated at little things like the chainguide not fitting and the fact that it didn't come with an axle (and my LBS didn't have any). Just a few more days...
  8. #533
    I reserved a 2012 M9 frame today. I'm pretty stoked but won't be building until February sometime.
    2012 Intense M9
    2008 Look 595
  9. #534
    Dec 2011
    cool.... i will want to get one....
  10. #535
    i had no problem mounting my SRS+ with only the thin spacer behind the backplate. the Mini G2SL i had fit fine too
  11. #536
    I'm planning on running a 38t guide ring so would obviously need a 36-40t guide to accompany it. My LG1+ would fit the bid but does anybody know what kind of modifications are we talking here? I really don't want to get a G2 if I don't have to.
    2012 Intense M9
    2008 Look 595
  12. #537
    With my fork arriving tomorrow I will have everything to complete my build minus the frame... I guess it's good to be excited about something.
    2012 Intense M9
    2008 Look 595
  13. #538
    I think you'd have to grind a bit of the back plate off where it crosses the seatstay on the swingarm. I didn't take any pictures when I was trying to mount it, but I'm sure you could get it to work with a bit of dremeling.
  14. #539
    Quote Originally Posted by mtbnozpikr View Post
    Here are a few shots I just took of my bike with the MRP G2SL. You can see the back of the MRP guide would hit the triangle if it were any larger. The e13 guide is taller and wider there, and I think rotated back more. I'm running 2 washers as spacers and the chainline looks pretty good. Hope that helps
    Attached Thumbnails Attached Thumbnails M9 Fro-imageuploadedbytapatalk1326762640.246823.jpg
  15. #540
    Thank you very much. I think that helps a lot. I will have everything to put the bike together tomorrow (minus the frame and the shifter cable/housing) and I think that I will end up just waiting until I actually start the build. I have been told by Intense that it should work but might need to be spaced more.
    My goal is to have everything ready to go so when the frame arrives in February I can build from start to finish in one shot. That said, if the e13 is too much trouble, I can get an MRP pretty quickly. Thanks again.
    2012 Intense M9
    2008 Look 595
  16. #541
    No worries, good luck on the build. I'm still waiting on a rear axle so I haven't had a chance to ride it yet. Soon hopefully...
  17. #542
    The fork came in today so all I'm waiting on are the frame and headset which should be here in February. Now I guess the trick is to be patient until it gets here...
    2012 Intense M9
    2008 Look 595
  18. #543
    selling my DB coil and just ordered a DB Air for my bike. should be shipped on 2/15.
  19. #544
    there are very nice bike parts..
    look this until your frame come inn... what color you order?
    Matt Beer 2011 Video Video - Pinkbike.com
    ride.
  20. #545
    is the rear axle not incl.??
    ride.
  21. #546
    Thanks for the link to the video. She's going to be red.
    2012 Intense M9
    2008 Look 595
  22. #547
    red is so nice!
    ride.
  23. #548
    It wasn't on mine, but mine was a warranty replacement for a cracked SOCOM. I know that the new frame at my LBS included an axle. A buddy gave me a steel one he had lying around, but the M9 dropouts are really thick and the axle only engages a few threads per side so I'm not real confident running it like that.
  24. #549
    ok., my original m9 axle without washer is excellent!
    ride.
  25. #550
    Some changes since last time:
    Ti spring from the classifieds
    e13 cranks 170mm in the CRC sale
    Easton Havoc carbon bars
    SDG Ti Fly saddle (sale)
    ODI Troy Lee grips (sale)
    I've a got Bos Stoy from the classifieds going on this weekend so no more CCDB. A great shock but a proper PITA.
