Page 20 of 25 FirstFirst ... 10 16 17 18 19 20 21 22 23 24 ... LastLast
Results 476 to 500 of 611
Thread: M9 Fro
  1. #476
    Quote Originally Posted by jimarin View Post
    To me it feels stiffer. When you hold the frame and move the wheel back and forth there is no noticable movement. That wasn't the case before, even when the bolts were freshly tightened.
    Thanks for the info!
  2. #477
    Quote Originally Posted by downplease View Post
    I went through all the hardware and checked torque to see if I missed something but it is all torqued and seated properly and it feels about the same as it did with the old hardware. i was hoping it would take a lot of the flex out of the rear end but if it does it's not enough that I can tell the difference. thanks for the tip i'll make sure to keep the collets well lubed.
    Quote Originally Posted by 8664 View Post
    this system looks like more work as the old... and kone stoper?? sorry that sucks!!!!
    if the bolt loose it self you need to remove the kone "hope it does" and than tighten the bolt and reinstall. the konus...
    that "kone" prevents the pivot axle from backing itself out since it helps flair out the pivot axle on the non-drive side.
    its what SC and Intense has been using for years on their other bikes. and if it actually does hold the pivot axle in place, i dont see how thats anymore work since you dont have to check your pivot after every ride
  4. #479
    Reputation: EF76's Avatar
    downplease, I endorse your asymmetrical decal removal...
    there is unrest in the forest. there is trouble with the trees.
  5. #480
    You found the rear end flexy?! This and the Tracer 2 are the stiffest Intense bikes I have ridden - very impressed!! I'm not sure I would want it any stiffer when running prebuilt wheels such as Deemax Ultimates (DH) or Easton Havens (xc).
  6. #481
    ive found the complete opposite of this bike. its the flexiest rear end ive ever had on a bike. hopefully the new setup will work better
  7. #482
    Reputation: mr intense's Avatar
    check your PM something is not right & I noticed some parts missing on the new setup in your photo.
  8. #483
    Jeff, can you post a pic or list the parts that are included/needed. hopefully they sent out my replacement link last week
  9. #484
    Deadatbirth: I am sure Jeff has plenty of time to provide you with a list of parts. He's only trying to run a business...
  10. #485
    Quote Originally Posted by Dwdrums00 View Post
    He seemed to care enough that the person above was missing parts, I'd figure he'd want to make sure no one else has issues
  11. #486
    Hello, i got a new M9 raw the rear end is only 145mm wide i have to spread out to make my 150mm wheel in.. is that a problem or can i ride without any danger... i check the rear for transport damage but nothing look like this..
    which tool you recommend for change the four box link bearings in the M9 front and rear??
    ride.
  12. #487
    Quote Originally Posted by deadatbirth View Post
    all you need
    Intense Cycles M9 Lower Box Link - Fanatik Bike Co. - Bellingham Wa
    ride.
  13. #488
    killer, thanks
  14. #489
    Quote Originally Posted by EF76 View Post
    Thanks. I wasn't sure if I'd like it all blacked out so I just did one side and then decided I liked it with and with out graphics so I've just left it that way.
  15. #490
    ride.
  16. #491
    first Dirt for my M9.
    <object width="600" height="338"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=33449271&amp;server=vimeo.co m&amp;show_title=0&amp;show_byline=0&amp;show_port rait=0&amp;color=00adef&amp;fullscreen=1&amp;autop lay=0&amp;loop=0" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=33449271&amp;server=vimeo.co m&amp;show_title=0&amp;show_byline=0&amp;show_port rait=0&amp;color=00adef&amp;fullscreen=1&amp;autop lay=0&amp;loop=0" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="600" height="338"></embed></object>
    ride.
  17. #492
    Nice bike, nice track ! Rather fast for an old man !
    What's the name of the sound ?
  18. #493
    Quote Originally Posted by san_andreas View Post
    thanks.
    sound from "la famiglia"
    ride.
  19. #494
    Reputation: kdiff's Avatar
    Nice riding
    Do you still have your 951?
  20. #495
    Thanks.
    no not more, if you have ride once a M9 you never need a 951.
    ride.
  21. #496
    not near my bike at the moment but does anyone know if the two grease ports are threaded or pressed in? when i replace my link setup i want to remove all the grease and then squeeze new lube into the cavity if those zirk fittings are removable. i have a grease gun but it takes forever to fill that whole cavity up.
  22. #497
    they are threaded
  23. #498
    my Baby
    ride.
  24. #499
    did you take apart your pedals recently?
  25. #500
    Reputation: squiby's Avatar
    Does anyone know the actual torque specs from Intense on the new lower pivots?
    I just threw the new link on my old SS1. Betterer system IMO. Used the Santa Cruz torque specs but I don't want to assume they are correct before I take it out for a little abuse.
    Edit: (to keep it on topic) I have another new link to throw on my M9 next.
