Page 12 of 13 FirstFirst ... 28910111213 LastLast
Results 551 to 600 of 611
Thread: M9 Fro
  1. #551
    How are your springs rates compared to the recommendations in the manual? I haven't had a chance to ride yet, but I'm curious. I'm about 230lbs and I'll be running a 500 or 550 lb spring per the CCDB table.
  2. #552
    im about 230 geared up and running a 450Ti for the 8.5-9" setting. sag is spot on
  3. #553
    Sweet, thanks for the info. I've got a 450 as well I can try. Good to know.
  4. #554
    Reputation: mtbnozpikr's Avatar
    I can't complain but as it turns out my frame showed up about 2-3 weeks early and will be delivered to me Tuesday. I'll post pictures when I finish the build.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  5. #555
    Quote Originally Posted by Bnorthro View Post
    I have a 550lb x 3.00 ti spring NEW for cheap just instant message.
  6. #556
    A large red M9 arrived at my place this afternoon. It is absolutely beautiful and I can say I am extremely impressed at the quality and workmanship of the frame. It is just about built up but I will post pictures after I get my brake lines replaced.
    2012 Intense M9
    2008 Look 595
  7. #557
    Nice! Congratulations. Curious to see how you get the e13 to fit.
  8. #558
    Thanks a bunch. The e13 fit very well without any problems or modifications. The upper guide is close to the rear triangle but doesn't touch at all. When I post pictures I'll post some of the spacing as well as the clearance.
    2012 Intense M9
    2008 Look 595
  9. #559
    Reputation: mzorich's Avatar
    Mar 2011
    is anyone running a double barrel air on their m9 yet. i am buying a m9 in 2 months and want to know if i should just get the bike with one on it since it is 150 bucks to upgrade in stead of getting it with the coil then going air later
  10. #560
    Many are happy with the CCDB but I could not get along with it, Saying that, it might be perfect for you..? Take your time, do some research and look into your options. There are plenty out there.
  11. #561
    Quote Originally Posted by mzorich View Post
    no one is yet. they just started shipping OEM shocks and customer shocks are shipping on the 15th....i should hopefully have mine soon after. i didnt think Intense was offering it as part of their upgrade yet.
  12. #562
    Mar 2011
    fanatik is offering it as an upgrade
  13. #563
    I don't see it listed on their website. Do you have to talk to them to get the swap?
    2012 Intense M9
    2008 Look 595
  14. #564
  15. #565
    Mar 2011
    i don't think they are actually selling it yet but if you go and build a complete m9 with the fanatik builder its and option
  16. #566
    As promised, here are a few pictures of my 36-40t e13 LG1+ fitted to the M9 frame without modification. I have two thicker black washers sandwiching a thin brass spacer for a total spacing of about 5mm. I have it tilted forward and am about 3-4mm away from the linkage.
    2012 Intense M9
    2008 Look 595
  17. #567
    Looking good, fit better than I thought it would.
  18. #568
    Thanks, I'll post pictures of the full build when I get the brake lines replaced probably (hopefully) next weekend. I've run both the MRP G2 and e13 LG1+ and think that they are just about equal products but I like the looks of the e13 better so I was very pleased when it fit. The fact that I didn't have to drop another $130 or so for the G2 SL wasn't too bad either...
    2012 Intense M9
    2008 Look 595
  19. #569
    Reputation: Intenseman's Avatar
    Mine....before Re-paint
    'Tentense...or Intenseman
  20. #570
    Reputation: goog's Avatar
    Quote Originally Posted by Intenseman View Post
    I wish I was your trash man
  21. #571
  22. #572
    I just got the brake lines replaced and picked it up this morning. A big thanks to Brian at Wrench Science. Can't wait to get out and ride.
    2012 Intense M9
    2008 Look 595
  23. #573
    Not sure what happened there but my two pictures were put side by side so I deleted the one to eliminate the majority of the side-scroll. Here is is:
    2012 Intense M9
    2008 Look 595
  24. #574
    <object width='500' height='281'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/245964/l/' /><embed src='http://www.pinkbike.com/v/245964/l/' type='application/x-shockwave-flash' width='500' height='281' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/245964/">Sunday ride</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    ride.
  25. #575
    @ mtbnozpikr
    sick ride!!
    ride.
  26. #576
    Reputation: ozzer's Avatar
    Out with team Yellow, in with the red for 2012 and beyond. I slapped the Deemax on in preparation for the Formula One season. Guess who's team/manufacturer I'm rooting for..
    Some sales guy (lol) at Intense has my only other Vivid Air but otherwise, it'd be on my bike.
    Currently at 39lbs right now and hella fun to throw around .
  27. #577
    sick ride!!
    ride.
  28. #578
    after several rides on the DB Air, i have to say that im really impressed with the shock. its on par, if not better then my coil DB. i am having to run the shock in the lowest progression setting but its been taking all the abuse ive been throwing at it.
  29. #579
    is there a big difrenz between the midle and upper "linear" progression setting?
    ride.
  30. #580
    Reputation: arthuar's Avatar
    Quote Originally Posted by 8664 View Post
    I don't know if I can call it big, but you can note it definetely.
    The bike, especially on rough and hard tracks, is more reactive; if you got used to pump it before the obstacle, it's better a lot.
    It depends on you, but, for my likes I prefer it less linear and more progressive (.. reactiveness helps!)
    Have a good time with this bike, it's sooo...good
  31. #581
    Quote Originally Posted by arthuar View Post
    ahh, if it is in the midle progressive.. hole you can push bump it before a jump...
    and in the upper hole is more plow..
    yes i wil have a nice time with this beast...
    9 or 9.5 travel?
    ride.
  32. #582
    Quote Originally Posted by ozzer View Post
    ride update.. as seen on Vital. New Dorado works great so far. The black E13 bashguard is 0.14 sec faster than the white.
    2013 Intense Bombers M9 - ozzer's Bike Check - Vital MTB
    I miss riding the M9. Been spending lots of time on the Carbine lately.
  33. #583
    Reputation: CoyoteRun's Avatar
    Like it you have the M9 stickers on the brake lever!
    How do you like the Dorado?
    Thanks,
  34. #584
    @ozzer,very nice with Dorado, what you make to the downtube? i ride the dorade now 7mt, can't be happier!!!
    my frame is on the way
    ride.
  35. #585
    How many M9's have you owned up to now? What happened to your Doberman Stella?
    2012 Intense M9
    2008 Look 595
  36. #586
    i like to ride diverse bikes.
    ride.
  37. #587
    Sounds good to me. What shock and fork are you going to have on your latest iteration?
    2012 Intense M9
    2008 Look 595
  38. #588
    Quote Originally Posted by mtbnozpikr View Post
    check this
    Life is beautiful
    fork dorado!
    ride.
  39. #589
    The down tube protection is the same downtube protection used on the Carbine -just slightly cutout to fit.
    (Jeff, better stock up and create a SKU to sell this stuff).
    I thought it was a neat novelty to have as a first line of defense for the highly battered spot of the frame.
    I really like my Dorado...so far. It's all just a matter of how reliable it's going to be from this point forward. So far, I LIKE it and two of the guys in our team have switched as well after taking my Dorado for a run or two.
  40. #590
    @ozzer
    thanks.
    is there a big difference between the boxxer and dorado... weigh,t small bumps feedback, fork rake ..?
    ride.
  41. #591
    Reputation: trojans1993's Avatar
    LizardSkins makes a "Carbon Leather" version that feels pretty tough and fits perfect on the M9 with just a couple tiny notches for the cable stays.
  42. #592
    super nice!
    ride.
  43. #593
  44. #594
    my fluo baby
    boom shakalaka
    16.32Kg
    ride.
  45. #595
    my fluo baby 16.32Kg
    Nice!
    2012 Intense M9
    2008 Look 595
  46. #596
    Dang, looking at all these slick rigs makes me want to ride - the 9 is getting some dirt action this weekend for sure. Nice job on your builds guys!
  47. #597
    that is a large size?
    ride.
  48. #598
    my medium have a 13.5cm headtube like a large frame but frame is a medium any idea why?
    EDIT:
    since mid 12" the medium hafe the same HT like the Large 13.4mm.
    ride.
  49. #599
    @ 8664, I am pretty sure Intense has always used the same head tube length for medium and large M9s. That goes for most of their frames with full 1.5" head tubes.
  50. #600
    Cool,
    ride.
