Results 1 to 10 of 10
    Reputation: FanatikBike.com's Avatar
    Dec 2008
    The lightest Carbine SL you've ever seen! (probably)
    Just got done building this up today, and thought the folks in this forum would probably enjoy checking it out! Build Spec:
    Carbine SL Small Frame
    Revelation WC XX Fork
    110 Headset
    ENVE Stem/Bar/Post
    Easton EC90 Wheelset w/XX1 Driver
    XX1 Drivetrain
    Schwalbe Racing Ralph 2.1 Evo SS Tires
    WTB Silverado Carbon
    XTR Race Brakes w/Formula R1 rotors and ti rotor bolts
    Final Build Weight: 21.5 lbs
    The lightest Carbine SL you've ever seen! (probably)-dsc_0128.jpgThe lightest Carbine SL you've ever seen! (probably)-dsc_0129.jpgThe lightest Carbine SL you've ever seen! (probably)-dsc_0130.jpgThe lightest Carbine SL you've ever seen! (probably)-dsc_0131.jpgThe lightest Carbine SL you've ever seen! (probably)-dsc_0133.jpgThe lightest Carbine SL you've ever seen! (probably)-dsc_0134.jpgThe lightest Carbine SL you've ever seen! (probably)-dsc_0135.jpgThe lightest Carbine SL you've ever seen! (probably)-dsc_0137.jpgThe lightest Carbine SL you've ever seen! (probably)-dsc_0141.jpg
    Reputation: Just J's Avatar
    Feb 2005
    That looks fantastic! Wow I'd love something like that in my stable for when the mood takes me!
    Insane!!!! good job guys!
    Reputation: JokerBoy's Avatar
    You Sick bastards . Beautiful job!!!
    "Nice bike...Take it off any sweet jumps?"
    get rid of that quick release seat collar for a bolt on one. You can save a little more weight. Sick build!
    Ole
    Ole is offline
    Wink
    Here's mine in Large, converted to 27.5 (dropped the BB accordingly), with Light Bicycle Wide carbon rims, Rocket Ron 2.25" tires and XX 2x10 setup. I'm also using a 10mm TA in the rear for increased stiffness. 19.84lbs as pictured.
    Reputation: Colin+M's Avatar
    Two frame sizes larger, bigger wheels/tires, 2x10 instead of XX1 , a mud flap/fender and almost 2lbs lighter than the one posted above? Something doesn't add up, literally.
    Can you post a parts list? I'm trying to drop some weight on my Spider Comp and I'm curious.
    Translation: I'm Jealous
    Jan 2011
    Search the forum for "Project Carbine SL 27.5", he uses Lightning cranks and MCFK seatpost, everything does add up... I am still jealous...
    edit for the cranks...
    Ole
    Ole is offline
    Lightning crank with Extralite Gara 28/42. XTR front der, XX rear der, cassette and triggers. Schmolke 660mm riserbar, Scmolke TLO seatpost, Extralite hubs (240g for the pair), 365g carbon rims (1174g wheelset), 1500g SID 120 27.5, Formula R1 brakes, Rotor stem, KCNC bottom headset, Extralite upper, and various small tweaks here and there to shave the last few grams. A bit of a bummer that the weight ended at 9.00kg and not 8.99kg. Maybe the Kettle rotors will fix that if they get the performance issue solved.
    Reputation: CarbineSL's Avatar
    Jul 2013
    With a bike that light, really hard to keep it on the ground. But maybe you want to fly?
    My SL is 26.4 pounds, light enough for me.
  1. Carbine SL - First Impressions
    By koertle in forum Intense
    Last Post: 11-01-2013, 06:13 PM
  2. Oh hello Intense Carbine 27.5....
    By hammerheadbikes in forum 27.5
    Last Post: 08-05-2013, 03:01 PM
  3. 275 vs Carbine
    By techfersure in forum Intense
    Last Post: 10-03-2012, 02:39 PM
  4. Carbine XL - Where is it at ?
    By Ob1Hoagie in forum Intense
    Last Post: 04-20-2012, 08:15 PM
  5. intense carbine
    By invol2ver in forum Intense
    Last Post: 08-12-2011, 05:57 AM
