Results 1 to 35 of 35
    For Intense crew... the site
    Why there isn't any clue for shock sizes at the site, is it a nuclear secret?
    Oct 2011
    Opinion deleted due to harassment and intimidation.
    The following suggestion was ignored, but will remain.
    Sam is the man:
    "I can guarantee all of you that each inquiry/issue/etc that crosses my desk is handled with my full personal attention. I invite everyone to email me at any time at Sam@Intensecycles.com or call my extension at 951-296-9596 x28. Even if it's just a "hello!" I need that sometimes anyways."
    Reputation: azmxr177's Avatar
    [QUOTE=grizfish;10770343]Components have always been fluid in nature. They come and they go. They change due to technology, price, availability, intended use, etc.
    Shock size isn't a component.... its a dimension on the frame just like head angle, BB height, top tube length......
    Aug 2010
    [QUOTE=azmxr177;10770974]
    Quote Originally Posted by grizfish View Post
    Exactly... Intense's website is far from helpful at times. Good thing I've only owned 5 of them. Its not difficult to include this information with the frame specifications.
    Oct 2011
    Well, pardon me ladies!
    I made an effort to help and you follow up by arguing semantics.
    "Changes were made because I have learned from several posters that shocks are not components and that each frame has one and only one shock size. However, I will continue to use the shock of my choosing if it works for me."
    The people at Intense are amazing. They retain their sanity after dealing with such dastardly creatures.
    You asked for shock size. Does that mean diameter of housing, diameter of rod, length of rod travel, overall shock total length from fully compressed to fully extended? Shocks are components, whether you like it or not.
    Wow.... Shock size is, eye to eye and stroke length....that's all, pretty simple. Yes, shocks are components, you can change out shocks all day long, but the SHOCK SIZE will not change. By your reply you don't know what size your own shock is....it's good to know, how do you set your sag if you don't now your stroke?
    A seatpost is a component, if someone wants to know the diameter of the seat tube you wouldn't say "a seatpost is a component, people change them out all the time, so the size of the seat tube isn't important".
    And I have no problem with Intense.....
    Reputation: slowrider's Avatar
    I agree that the Intense web site lacks some vital information but shock size hasn't been the one I've missed. When I was shopping bikes I noticed that they included wheelbase, standover, reach and stack on a hit or miss basis, making it tough to compare bikes.
    I thought I saw shock size for the Tracer 29 awhile back??
    insert sarcasm here
    Reputation: gbug's Avatar
    Quote Originally Posted by azmxr177 View Post
    +1 Azmxr
    I'm always looking for new people to ride with. If you are on the Front Range, shoot me a PM and let's go ridin'.
    Lord of the Chain Rings
    Reputation: orastreet's Avatar
    Give this guy a break, with the spacers and high seat post. Being taller you have to sometimes make these "unsightly" adjustments to make the bike fit. I wish Intense made an XL. But they don't, so like me, being 6'3 on 26 inch wheels, sometimes you dwarf your bike even though it technically fits. I will say that whenever I photograph my bike I always drop the seat! Bike is beautiful! Now go take if off some jumps.
    Uzzi
    We're not talking about adjustable things like seatpost.... We're talking about fixed dimensions of the FRAME.
    Reputation: CarbineSL's Avatar
    Jul 2013
    The Intense website tells you which rear shock comes with the bike. My carbine SL comes with a Fox Float CTD. Not difficult to look this up on the Fox website.
    FLOAT CTD Boost Valve w/Trail Adjust Bike Shock | FOX
    Everything you need to know is there. How easy was that?
    Front shock? Well, that does get a bit more complicated, since unless you buy built up, you have to figure that out for yourself. But Intense gives us a clue on the website, via showing us the Carbine SL is 26", and their figure illustrates Geometry with 120 - 150 mm travel. So we should select a 180 mm travel fork? Well, since this is not a downhill bike, that's a bad idea. How about a single crown fork, either 120 or 150 mm? Any brand that impresses you will do. Or any brand that you can find conveniently nearby at your local LBS. Or how about a Fox 32 Talas 26 120/150? 32 TALAS 26 150/120 FIT CTD Trail Adjust Bike Fork | FOX
    That's what I have on my bike. Rocket science diploma not required.
    Quote Originally Posted by CarbineSL View Post
    Whats the eye-to-eye and stroke of your rear shock?
    By the way, the 1st post was about shock size, not forks or "front shocks" as you called them.
    Just because it says what kind of shock it come's with doesn't tell you sh!t....Rear shocks come in a lot of sized for different frames. My shock for example, is a 8.5"x2.5". How easy was that?
    Reputation: dropmachine.com's Avatar
    I'm trying desperately to land the Intense site as a project. That site drives me absolutely crazy with its nonsensical design and random links. ANd unreadable text. And lack of real information. And lack of past model info. And lack of EVERY BLOODY THING A WEBSITE IS SUPPOSED TO DO>
    Once I finish the Hadley site, they are tops on my list. Wish me luck
    Stuff.
    Thanks....and good luck, we appreciate it!!
    FLOAT CTD Boost Valve w/Trail Adjust Bike Shock | FOX[/URL]
    Clueless.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Quote Originally Posted by twotone View Post
    clueless.
    thank you!!!
    I think they website is there for selling T-Shirts... Just kidding! I love Intense and have just about every T-Shirt they ever made. I hope Jeff S. doesn't cut me off from owning any more Intense frames!
    Ironically, as of this posting, the website appears to be down.
    Uzzi
    Oct 2011
    "Clueless."
    Thanks for the enlightenment. But, I'm still calling your mother.
    "Clueless."
    I'm not the one that posted a bunch of crap out of my ... then got mad when I was corrected. It had nothing to do with symantics just you and the other poster being clueless.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Jul 2013
    The eye to eye is easy to measure. Mine is 7.785. Because the same eye to eye can have a different stroke, (as shown on the Fox page, there is a 7.875 X 2.00 and 7.875 x 2.25) it may be hard to figure out the stroke. The fox Tech center
    WebHelp
    says that the weight of the shocks will be different:
    0.64 lbs. / 290 g
    (6.75" x 1.75", no reducers)
    0.67 lbs. / 303 g
    (7.25" x 2.00", no reducers)
    0.70 lbs. / 317 g
    (7.75" x 2.25", no reducers)
    So a 7.875 x 2.00 will weigh 303g, and a 7.785 x 2.25 will weigh 317g
    Get a scale and weigh your RP23.
    You're just pulling sh!t off Fox's website. Fox can't tell you what size shock will fit witch Intense frame. My frame takes a DIFFERENT shock SIZE than yours!!! Some people want to know the shock SIZE for a specific INTENSE FRAME..... Give up, you don't what WE'RE talking about.
    And don't lecture me on shock size, I know what the F I'm talking about.....I can tell you every shock size off all my bikes from the past 10 years off the top of my head.
    Don't waste your time, they are the type that buys a bike and never change anything so have no concept on why you'd need to know the shock size for a specific frame before buying.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Oct 2011
    IMO: If you are unable to determine the length and travel you want for your shock then you will remain in virtual limbo with 2tone and azmxr. The devil will have them forever criticizing and complaining about the things others do to them. They are condemned to never be able to determine anything on their own. They will remain oblivious to reality into their own eternity.
    Be advised: This is not necessarily a bad or uncommon condition. It is often referred to as being "fat, dumb and happy."
    Funny thing is you make this comment when you didn't even know what the OP meant by shock size to begin with. So tell me genius, if you don't have the frame already, how do you determine the shock size?
    See it's actually you that is "fat, dumb and happy." You're perfectly content with the shock that comes on a bike you buy, so you can't fathom why someone might need that info.
    See unlike you I know exactly what I want- a CCDBAcs on my next bike, so part of shopping a frame is knowing the shock size since they only come in certain sizes and will not fit all frames.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    insert sarcasm here
    This has been quite the painful read.
    Either you're doing a decent job of trolling, or you're from Oklahoma. Dumb people (as you referred to above) generally don't know anything. Oklahomans? They don't even suspect anything.
    Do us all a favor and don't ever give out component advice again, ever.
    Feb 2006
    I agree with the above poster about the website generally. It is anything but user friendly.
    Quote Originally Posted by TwoTone View Post
    At least someone knows what they're talking about....
    beater
    Reputation: evasive's Avatar
    Feb 2005
    I'm amazed people want to argue about this.
    For any small/midsize company that sells a lot of frames versus complete bikes, there really isn't any excuse for not providing the shock specs on the geometry or spec page. Banshee and Knolly also provide the mounting hardware dimensions. You need to know all of that if you're replacing or upgrading a shock.
    Trail Ninja
    Reputation: Varaxis's Avatar
    All this arguing over semantics is why marketing even exists, to fill the gap between those that overthink things and maintain their own dictionary of accurate terms and definitions for differentiating smaller details, and those that want some simplified piece of information and don't sweat all the smaller details and call it some vague term. Reminds of one scenario where a guy looking for a headset cap bolt and CS directs them to the hardware store, and they're like Home Depot doesn't carry "headset cap bolts", and CS needs to point out it's a M6 x 1 x 25 socket cap head bolt... looks like Intense may be in need of a marketing guy to translate stuff to the "consumer-ese" language. I hate marketing. Wish the more accurate/proper terms were used by all.
    Funny thread... 1 guy wants to know "shock size", but actually wants to know the stock rear shock eye to eye and stroke length, and a big deal is made out of all this. I'd expect arguments over semantics from nerds, but... well, I guess bike nerds are nerds too. All this could have been solved by a ruler bought for 50 cents at the office supply store, or a tape measure borrowed from your dad, or a measuring tape from your mom. Apparently instead of that, people demand a website to be updated and rather than provide feedback directly by contacting them, they complain openly on a forum.
    Was looking at the Intense site and I actually do see shock eye-to-eye and stroke length listed for some frames. Looks like they use longer 9.5" x 3.0" shocks for DH and shorter 7.875" x 2.25" for XC/trail. What frame is the OP talking about?
    We're all on the same ship, and it's sinking.
    Well, my Tracer 2 is 8.5" x 2.5" which is bigger than the Tracer 275 and Tracer 29. So there are a few different sizes on the different frames.
    They don't list the shock size for the Hard Eddie....
    Wait for it...
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    All this info used to be in the Intense online manual, which I haven't seen posted since 2010. I have that 2010 PDF, so if someone really needs it, PM me and I can send it to you. It had shock size, mounting hardware size, geometry, torques, etc. I use it all the time when maintaining my Tracer VP. Wish I had the same thing for my new (to me) 2012 Spider 2.
    GT
    Order the Frame with a CCDB, they are pretty smart guys and can usually get you taken care of. They have great customer service, all you need to do is call.
  1. Replies: 6
    Last Post: 09-18-2013, 01:59 AM
  2. Replies: 76
    Last Post: 06-08-2012, 01:20 PM
  3. Replies: 4
    Last Post: 05-18-2012, 08:46 AM
  4. Video of KHS crew rippin the Rampage site
    By A-NON-A in forum Downhill - Freeride
    Last Post: 02-11-2012, 10:17 PM
  5. intense site videos
    By demrgo in forum Intense
    Last Post: 05-12-2011, 04:04 AM
