    Intense Carbine Linkage Question
    I have a 2012 Intense Carbine 275 and the linkage bolts seem to be loose within every two rides. I ride hard on trails which are really more XC on average than AM. Does anybody else have experience with this? I was thinking of applying locktite, but am not sure that is a good idea. Any recommendations would be most appreciated. Thanks.
    Dec 2005
    Apply Locktite and torque to proper specs and you should be just fine. I am on my fourth Intense and have never had an issue with the linkage bolts after I bought my torque wrench.
    Call Intense to get the proper torque specs as they are quite high and undertightening will lead to chronic loosening. If you don't have a torque wrench, I highly recommend you pick one up.
    Here are the specs for my Spider Comp. I would presume the Carbine's are very similiar.
    125 inch lbs, upper two bolts on swing link
    175 inch lbs, lower two bolts on swing link
    Thanks so much! I have a call into Intense for the specs.
    BarBanger
    Mine also came loose on the first few rides. I locktited them and torqued to spec, and it started making horrible creaking sounds. Removed locktite, retorqued, and the creak went away and the bolts have been solid since.
  1. Intense Carbine 275
    By cebv84 in forum 27.5
    Last Post: 10-07-2013, 10:27 PM
  2. Oh hello Intense Carbine 27.5....
    By hammerheadbikes in forum 27.5
    Last Post: 08-05-2013, 03:01 PM
  3. Intense Carbine 29
    By hillharman in forum 29er Bikes
    Last Post: 07-29-2013, 11:54 AM
  4. Intense Carbine 27.5
    By Ridnw/bear in forum 27.5
    Last Post: 09-14-2012, 12:55 PM
  5. intense carbine
    By invol2ver in forum Intense
    Last Post: 08-12-2011, 05:57 AM
