Results 1 to 2 of 2
    Intense Carbine 29 with Pike 150/120 Dual Position
    Looking at the Carbine 29. For the trails and stuff I ride, I think a 160mm fork is a bit overkill, especially on a 29er. Right now, I'm riding a 26" Remedy with a 150mm Revelation and it's pretty good. I've also tried a 140mm (Fox 34) Remedy 29 out west (Moab), and that was perfect there.
    I was thinking of putting the Dual Position 150/120mm Pike on the Carbine. It would steepen the head angle like 0.1-2 degrees, which is a bonus. It would lower the BB a smidgen, perfect, and it would allow me to drop to 120mm for steep technical climbing so as to prevent the front end from wandering as much, I'll be using a 60mm stem.
    Any thoughts or comments on that? The only issue here is that it seems the 150/120 Dual Position 51mm comes in white only. That's a SRAM Fail.
    -Tom
    mtnbkr4life
    Nov 2008
    My only comment is I thought the same thing until I rode mine
    The 160/140 combo on this frame is "Amazing"
    I have a "Custom" Build 2015 which is for sale(too many bikes AGAIN)
  1. Pike SO vs Dual Position?
    By myitch in forum All Mountain
    Last Post: 05-23-2015, 12:31 PM
  2. Can a Pike 29 dual position change from 120 to 140?
    By trhoppe in forum Shocks and Suspension
    Last Post: 03-04-2015, 05:07 AM
  3. Pike Solo Air vs: Dual Position
    By myitch in forum SRAM
    Last Post: 01-18-2015, 10:47 AM
  4. Pike dual position axle-crown
    By cwilsun in forum 29er Components
    Last Post: 08-28-2013, 08:00 AM
  5. New Pike RCT3 Dual Position Air
    By HeatmiserSoCal in forum Shocks and Suspension
    Last Post: 08-12-2013, 02:56 PM
