Results 1 to 5 of 5
    Feb 2006
    Intense Carbine 275 Geometry question
    Looking at maybe purchasing one of these frames. I see the frame can be setup to either 5.5" or 6" travel.
    With the shock set to 5.5" travel does this change the geometry at all? Does it lower the bottom bracket? or does the geometry remain the same.
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    Quote Originally Posted by VERT1 View Post
    Adjusting the travel is independent of the geometry of the bike. The bike does ride quite a bit different in each setting though, and you'll have to adjust shock pressure to compensate for the changes in leverage when changing the travel.
    Sam Wilson
    Things & Stuff Specialist
    Beer Drinker
    Intense Cycles, Inc.
    Sam@Intensecycles.com
    May 2005
    @ Sam: do you know the standover height for the Carbine 275 (small and medium frame)? Thank you in advance!
    Which position is the longer travel option for the rear shock, the top mount hole or bottom?
    Feb 2006
    Re: Intense Carbine 275 Geometry question
    Quote Originally Posted by Sam-IntenseCustServ View Post
    What happens to the leverage when setting to 5.5"
    Sent from my SM-N9005 using Tapatalk
  1. Intense Carbine 275
    By cebv84 in forum 27.5
    Last Post: 10-07-2013, 10:27 PM
  2. Intense Carbine Linkage Question
    By mjj1066 in forum Intense
    Last Post: 09-21-2013, 03:52 AM
  3. Oh hello Intense Carbine 27.5....
    By hammerheadbikes in forum 27.5
    Last Post: 08-05-2013, 03:01 PM
  4. Intense Carbine 27.5
    By Ridnw/bear in forum 27.5
    Last Post: 09-14-2012, 12:55 PM
  5. intense carbine
    By invol2ver in forum Intense
    Last Post: 08-12-2011, 05:57 AM
