    Jan 2005
    Intense 6.6/DHX Shock Manual
    Is there a downloadable manual for the Intense 6.6? I need to know what air pressures to run for my weight(175 w/gear). I downloaded the Fox DHX Air manual from Fox but it doesn't have a guide for weight.
    ---rant mode on---
    I am completely disappointed in Intenses website or lack thereof. Foes has a clean, excellent website packed full of everything you need. It doesn't load in a second window sized down either. Intense isn't the only one guilty of a wannabe fancy nonfunctional website.
    --rant mode off---
    rain rain go away...
    Reputation: peachy-B's Avatar
    yeah... it's fancy but useless.
    Reputation: tmoney's Avatar
    I have a medium 6.6 and weigh about the same as you. I run about 220-230 psi in main chamber, 100-125 psi in boost valve with the volume screwed in all the way. That seems to work the best for me. Good luck with your tuning.
    -tmoney
    011100000110111101101111
    Reputation: unfluid one's Avatar
    Aug 2005
    Quote Originally Posted by tmoney
    -tmoney
    i'm acutally running my pressure low.. about 172 in the main. the boost..
    i'm running whatever it came as (what is it...100psi?)
    seems so damn more plush than when I was running 200, but i haven't gone on any big drops.
    I weigh about 168 without my hydration pack
    also i am a newb with a rear shock ... so what do i know?
