Results 1 to 6 of 6
    Intense 5.5 FRO 08 headset help
    Hi, I have a 08 5.5 FRO which i was planning to change the current headset to a Chris King,
    I am not too sure if this is the correct headset that i have to order. can anyone kindly advice me?
    http://www.aspirevelotech.com/Mercha...de=CKNTS-INSET
    T.W.O.
    Reputation: mimi1885's Avatar
    The links is not good.
    But if I read that correctly, it's the inset headset. You'd need the standard King headset 1 1/8" headset.
    Arnborg strik
    Reputation: Thomas's Avatar
    you cannot use the Chris King
    Quote Originally Posted by Jhanney
    The frame needs an internal headset.
    **PLEASE NOTE: This frame requires a 45/45 internal headset such as the FSA Orbit C 45x45
    T.W.O.
    Sorry, I thought it uses standard HS, thanks for the info.
    hi thomas and thanks mimi1885,
    well reason for changing headset is because of the talas 32 rlc fork being used has the knobs hitting the frame. i need the 5m ck crown race to get more clearance. so therefore the need to change. but how do i know if the ck is 45x45? will the headtube break if i used someother bearing angle? sorry not too sure the terms here.
    Arnborg strik
    You need
    a internal headset for the FRO.
    Chris king does NOT make a internal headset.
