Results 1 to 8 of 8
    Dec 2013
    Input from Short Spider29 Comp Riders
    First post, been lurking for a while. I have been deciding between getting a Santa Cruz Bronson or a Spider 29 Comp. Two different bikes, I know, but since I already have a NomadC, I've decided to go with the Spider.
    It appears I'm in between frame sizes on the Spider Comp. I'm 5'7", evenly proportioned, so the medium is just a little stretched out for me. I'll probably need a 50mm stem, and I won't be able to use the Reverb Stealth since it's not offered in 100mm lengths I don't think.
    The small will mean running an 80-90mm stem. This will be my first 29er, and it sounds like it's preferable to go down in size when in between frames. True? However, I'd also like to keep my stem length fairly short. I'm wondering if anyone on here is in the 5'6"-5'7" range riding a Spider Comp, and what size it is, what stem, etc. I know a lot of this has to do with your personal measurements, but it'd be a start.
    Thanks.
    Quote Originally Posted by RollinDirt View Post
    Thanks.
    I am also about the same height as you and I went with a small Spider Comp 29 frame based from the feedback I got from Sam (from Intense).
    I am in the process of getting the bike assembled and I am using a 0deg 70mm stem that I have from an old bike. I'll get you some updates once the bike is ready.
    Feb 2013
    I'm 5"8' and ride a small also with a 70mm stem. I prefer my frames small and this is a perfect fit for me. A medium would definately be too big.
    Dec 2013
    Thanks for the feedback. I've been riding Santa Cruz's so long and always am on a medium, but it looks like that won't be the case here.
    going to extremes....
    5.4.... Spider S.... 80mm Stem....
    Reputation: Ufdah's Avatar
    Sep 2012
    I agree w/ the above, Spider Comp's run large. I'm 6'3" and usually use an XL but the L fits me better than any bike I've ever ridden.
    Got the bike today and the 70mm stem fits good to me. I'll get you some more updates when I get to put some number of rides on the bike.
    Quote Originally Posted by dromayn View Post
    Attached Thumbnails Attached Thumbnails Input from Short Spider29 Comp Riders-photo-1.jpg
    I 1.70 meters (5 feet6 in) and got a medium, whit out trying. I have problems whit the height of the reverb and can not seem to find the sweet spot, I install a 50 mm renthal to shorten the reach, but I am still try to adapt to the bike.
    Going with the medium was a mistake, My old intense 6.6 was a medium and my Mojo Sl is a medium too, I got this because I try a pivot 429 carbon and a yeti sb95 in small those felt great but experienced some foot rub with the front tire. I would say try before you buy if it is possible
  1. Replies: 45
    Last Post: 05-12-2015, 04:09 AM
  2. Oregon Riders - your input requested
    By StreamRider in forum Oregon
    Last Post: 07-11-2013, 04:56 PM
  3. big riders i need input... coil vs air
    By itstreky in forum Downhill - Freeride
    Last Post: 03-29-2012, 02:00 PM
  4. experienced riders' input appreciated
    By MD_TX in forum General Discussion
    Last Post: 12-11-2011, 01:18 AM
  5. Spider29 VS Trace29
    By ALS650L in forum Intense
    Last Post: 06-21-2011, 05:28 PM
