Results 1 to 3 of 3
    How do you internally route Reverb on Spider 29 comp?
    I am trying to install the reverb stealth. Any tips for how do I make the housing turn to come back up the seat tube? Thanks.
    Get yourself a coat hanger, straighten it out and fashion a hook on one end.
    Slightly kink the end of the hydraulic hose so it is pointing up when it comes out of the down tube and in to the seat tube.
    Using a flashlight to see in the seat tube, insert the coat hanger into the seat tube and hook onto the hose. You will have to help push the hose through at the down tube with one hand and pull the coat hanger with the other. My wife was holding the flashlight.
    I had some prior experience building Kleins when I worked at a bike shop so it only took me about two minutes.
    Good luck.
    As said above. But you may also need patience. Lots of patience....
  1. Spider 29 vs. Spider comp 29
    By Danish Dynamite in forum Intense
    Last Post: 07-07-2013, 02:50 PM
  2. My new Spider Comp
    By smithrider in forum 29er Bikes
    Last Post: 02-09-2013, 08:02 AM
  3. My new Spider 29 Comp!!!
    By SaxMan2001 in forum Intense
    Last Post: 01-29-2013, 07:54 PM
  4. Spider Comp
    By mbernard71 in forum Intense
    Last Post: 01-14-2013, 09:38 PM
  5. My new Spider 29 Comp!!!!
    By SaxMan2001 in forum 29er Bikes
    Last Post: 01-14-2013, 05:47 PM
