Results 1 to 11 of 11
    caninus xerophilous
    Reputation: SunDog's Avatar
    Help: VPX, Dee-max, and Saint axle.
    I am trying to complete the build on my VPX and have encountered spacing issues with the rear drop outs and the Dee-Max wheelset w/Saint axle adaptor.
    The stock drop outs are oversized and the Intense provided spacers are too wide to accomidate the Mavic Saint axle, there is play on both sides.
    Anyone have experience to share regarding this problem? Can Intense provide the appropriate spacers or alternative drop outs?
    Thanks.
    Reputation: CoyoteRun's Avatar
    Quote Originally Posted by SunDog
    Thanks.
    any pictures?
    Now with flavor!!
    Reputation: kidwoo's Avatar
    This shouldn't be happening. I got a used set of deemaxes that the guy was running a saint axle with on an uzzi. From what I can tell, he didn't use the spacers though. I've still got the axle at home.
    In theory, the saint bolt should be the exact same diameter as the bolt on bits.
    I'll see if it fits when I leave work today.
    I can tell you right now though, if it were me, I'd just drill out the spacers to make it fit.
    Quote Originally Posted by kidwoo
    As you know there are two different spacers from the Uzzi and M3. One set is for the 9mm QR and the other set, which are thicker is for the thru 12mm axle.
    Since the Saint axle is 10mm, I beleive the QR spacers should be use. If the axle is too wide, you might need to drill the spacers to make it bigger.
    Saucy Size
    Reputation: Paul B's Avatar
    Thanks.
    Whoa whoa whoa whoa...hold on a second. Wait just a cotton pickin' minute.
    You got a VPX? And didn't tell me. Ooh! Lemme play with it!
    p.
    Don't be that guy! Read the forum guidelines.
    rain rain go away...
    Reputation: peachy-B's Avatar
    Maybe his Saint axle is 12mm... they come in 2 flavours.
    Quote Originally Posted by peachy-B
    If his VPX is a 150 spacing, that will be yes.
    Either 10 x 135mm or 12 x 150mm.
    Reputation: E2@CC's Avatar
    Dec 2005
    ... and if we just ...
    Thanks.
    Sun Dog-
    First thing to do is measure you're dropouts, if they measure 135mm spacing the axle works with the Smaller of the two spacers. The spacer I'm referring to has got a step down design to it. You need a sharpie marker, and a drimmel tool, and maybe a rattail file. You want to install the spacer on the back of the rear derailluer so you can trace out the der. stop on the saint rear derailleur.( are you using the saint with the saint axle, if not get the standard axle, and dissregaurd this post?) Next step is to drimmel out ONLY the area where the bump stop of the rear der. will contact. Try not to cut the groove so deep that you lose the step down part off of the spacer, but it does need to be deep enough that it it allows the der. to "bottom out" on the spacer, basically cut to the top of the step down. After that is done, you need to install the spacers, from the outside of the dropout, it is easier to line the rear wheel up in the dropout first then install the spacers accordingly....obviosly the "cutout" spacer will need to go on the drive side, face the cutout part down so as to allow the rear der. stop to contact the spacer correctly. Tighten her up and it should be good to go. Call me if you have any ?s...888-276-7130, or email; to eric@competitivecyclist.com. You can go to our photo gallery on the bottom of the page on the mountain bike home page and view a couple of the Uzzi's we've done with the same saint-deemax configuration. Hope this info. helps. If you mess up any of the spacers, call and we'll get you some more. Man maybe I should sell these things pre-fabricated. Eric(E2).
    I had this issue last year with my VPX. I had a 12mm x 150 Saint hub and Saint RD.
    The issue is that there is a small recess on the outside of the dropouts which 1) makes it so the RD wont sit properly in the dropout and 2) the axle tread wont bottom out properly on the RD leaving play. None of the spacers Intense supply rectifies this. All I got with my frame was a 12 * 10mm conversion washer I believe. To make the setup work I had to modify the drive side dropout so that the Saint RD tab would sit correctly in the slot and add a washer on the non-drive side to eliminate the spacing issue. The interior droupout spacing is right; the outer (due to the recess) is not compatible with Saint - as it ships. It is a pretty big oversight on their part IMO considering they showed the bike at Interbike that year with a Saint RD. I am surprised no one else had commented on this. Surely Intense has a solution. Saint dropouts maybe? Basically the dropouts would need to be flush on the outside like they are on the inside. Maybe an Intense staff member can offer up a solution? I would like to know as I will be running the same setup on my M3 for ’06.
    caninus xerophilous
    Spot on Eric. I am running the 135mm drop outs with a Deemax Saint Adaptor axle.
    I ruined one of the spacers trying to modify it before the OP. I am ordering some new spacers from Intense. SO I should get it right this time.
    I also have another issue with the Dee-Max Saint Axel on the non drive side, it cracked along the hex lines. They were real skimpy on they metal andI am worried that if I replace the axle the crack may re-occur. In your experience, are these things durable?
    Dec 2005
    Sun Dog-
    I have a buddy who weighs about 190-200, and he has had no problems with his setup. So I guess the metal is strong as far as riding goes, but they are machined out pretty slim around the allen hole. Here's a tip to try.....Do not tighten the rear der all the way onto the axle, leave a couple threads showing from fully tightened, you will want to hold the allen wrench in position while tightening the nut on the same side, AFTER threading the der. on the axle. You do not need to tighten it very much using the allen wrench, let the axle nut take the torque. If you tighten it too much the hub will not spin as freely as it should, (you may have figured this out by now). Once the wheel is installed you can use your Mavic hub tool to adjust the tension on the rear wheel. Glad to be of assistance. Enjoy your bike, the Uzzi is deffinitely an awesome rig. If you ever have anymore ?'s drop me an email eric@competitivecyclist.com.
    Ride On-
    E2
