Results 1 to 3 of 3
    grease injection trouble on a SS2
    I am having trouble injecting grease into my lower pivot using the Lubrimatic Mini Grease gun. I have tried cycling the shock prior to injection but the grease just backs out of the head. Any advise? Thanks!
    Aug 2010
    Quote Originally Posted by wonny View Post
    I'm assuming you have the older style press in zerk fittings? This is typical of the early style press in zerk fittings.. the support spring gets pushed into the void behind the zerk and the ball then blocks the grease you are trying to squeeze in... Best option is to either remove the zerk and inject grease, or install a new zerk fitting. The newer threaded style zerks seem to be a bit more robust and user friendly.
    Reputation: elcaro1101's Avatar
    It also helps to loosen the pivot bolts and take the air out of the suspension.
  1. Help with zerk injection
    By Phishin Paul in forum Ventana
    Last Post: 02-05-2014, 02:25 PM
  2. What Type of Grease for Grease Ports?
    By B-Line in forum Santa Cruz
    Last Post: 10-28-2012, 05:06 PM
  3. Grease gun and grease recommendation
    By wonny in forum Intense
    Last Post: 10-17-2012, 11:35 PM
  4. Chris King BB and Grease Injection Tool
    By MarkMass in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2012, 10:11 PM
  5. Im having some trouble
    By dpugh5 in forum Wheels and Tires
    Last Post: 11-02-2011, 12:19 PM
