Results 1 to 9 of 9
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    Frameset Exploded Views // Torque Values
    For anyone interested:
    Please note that assembly/torque for Carbine 29 will be the exact same as Spider 29 Comp
    951 EVO_Expl.PDF
    Hard Eddie_Exploded.PDF
    M9_Exploded_View_Drawing.PDF
    Spider29C_Exploded.PDF
    T275C_Exploded.PDF
    Tracer 275 Exploded Frame.PDF
    Carbine275_Exploded.PDF
    Any other questions? Fire 'em off...
    Sam Wilson
    Things & Stuff Specialist
    Beer Drinker
    Intense Cycles, Inc.
    Sam@Intensecycles.com
    Perfect - thanks :-=
    1. What is torque for the 2011 Spider 29 and Tracer 2?
    2. Should I loctite the bolts when tightening the lower link on the 2011 Spider 29? It does not seem possible to loctite the female threads on this link. I have only loosened the bolts so far on the lower link.
    Quote Originally Posted by Danish Dynamite View Post
    Follow Tracer 275 torque values for both your Spider 29 and Tracer 2. If your Spider 29 uses the older style lower linkage (non-expander style), then you'll need to use some loctite here and torque to 150 in/lb (17 NM). Newer expander main pivot bolts will not need any loctite- just grease. All upper linkage bolts for all models will require loctite (Blue #243).
    Sam Wilson
    Beer Drinker
    Rb
    Rb is offline
    Feb 2007
    Thanks Sam! This is super helpful.
    Reputation: deesta's Avatar
    6.6 available?
    Can you recommend a tool for pressing and pulling bearings in and outon Intense frames?
    Aside from having a knowledgeable shop do it for you, Wheels MFG makes some great tools for this: Presses & Extractors
    Sam Wilson
    Beer Drinker
    Quote Originally Posted by deesta View Post
    6.6 available?
    6.6 drawing not available, but send over an email if you have any questions. Torque for that frame's pivot bolts will be 175 in/lb on all 4 upper linkage bolts and 150 in/lb on lower main pivot bolts. Loctite on all bolts.
    Sam Wilson
    Beer Drinker
    Thanks Sam
  1. V10 Carbon Torque Values
    By IntenseMack10 in forum Santa Cruz
    Last Post: 12-16-2013, 05:04 AM
  2. El Comandante Torque values ?
    By SlowPokePete in forum Ventana
    Last Post: 10-20-2012, 06:05 AM
  3. El Comandante Torque Values ?
    By SlowPokePete in forum Singlespeed
    Last Post: 10-13-2012, 03:12 PM
  4. Enduro SL torque values
    By JonathanGennick in forum Specialized
    Last Post: 05-16-2012, 10:12 AM
  5. Linkage torque values?
    By inteq9 in forum Motobecane
    Last Post: 03-15-2011, 08:21 PM
