Results 1 to 8 of 8
    Reputation: BlueRidgeRider's Avatar
    Dec 2004
    Enduro Max Bearings
    Hello
    Does anybody have the actual Enduro Max bearing serial numbers for a Socom and a 5.5. I believe they start with a 6...
    Thanks for your help
    Reputation: kntr's Avatar
    I dont have the numbers but for some reason the regular Enduro bearings lasts longer than the Max for me. They have made less noise too.
    Reputation: bikeman_2's Avatar
    Quote Originally Posted by BlueRidgeRider
    Hello
    ...for the Linkage: 6001 But use INA or SKF bearings, not the fu... bearings from ENDURO!!!
    Reputation: Ronnie's Avatar
    Quote Originally Posted by bikeman_2
    I completely dissagree with you. The Enduro bearings have no ball cages and have MAXimum number of balls. They are made as pivot bearings. Bearings like the SKF which have ball cages are made for high speed rotation and not back and forth pivoting loads. And yes... I have used a set of SKF.
    Ronnie.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    Talk to these guys if you need bearings.
    http://www.enduroforkseals.com/id55.html
    Dec 2004
    looks like the new kits are using the enduro 7001, could be worth a shot.
    Dec 2004
    it's the enduro quality that sucks and SKF has many options including much better seals.
    http://www.skf.com/files/059324.pdf
    Dec 2004
    bearing help
    Thanks everybody for your help. I got a pretty good run out of the Enduro bearings for East Coast weather...funny, the Socom bearings lasted a good while longer than my 5.5's did.
