Results 1 to 3 of 3
    dab
    dab is offline
    Double Barrel Air on 2012 UZZI
    I was wondering which configuration of DB Air works best on a 2012 UZZI. Are people using the standard air can or the XV air can? I weigh 185lb in full riding gear and currently using an Avalanched modified Fox Van RC with a 400lb TI spring. This setup works great, but I am curious about the DB Air, if you riders using the DB air can post your feed back it would be great.
    Aug 2010
    I would recommend the XV air can on the Uzzi. I've tried the DB Air on the Uzzi and 951 with the standard air can and it was not possible to achieve full travel. That being said even the XV air can does not guarantee it will be a good match for the progressive nature of the Uzzi.
    Reputation: Shredman69's Avatar
    Quote Originally Posted by dab View Post
    The new CCDBA's come with a larger internal can. I got my 2013 with it and it was great, I used full travel no problem. I put on an XV can from my Nomad and it's even better. It's really linear now and matches my 36 Fox Float 180 perfectly.
    13 Intense Uzzi
    06 Santa Cruz Nomad
    00 Santa Cruz Bullit
    26er's for life!!!
  1. Replies: 34
    Last Post: 09-19-2013, 01:27 PM
  2. TRC with double barrel air?
    By The Beater in forum Santa Cruz
    Last Post: 06-17-2013, 08:27 AM
  3. Double Barrel Air and the 2011-2012 ONE
    By cosmoworks in forum Canfield
    Last Post: 11-16-2012, 10:00 PM
  4. Max pressure in the double barrel air?
    By david8613 in forum Shocks and Suspension
    Last Post: 07-05-2012, 06:38 PM
  5. Double Barrel Air
    By Mr. Blonde in forum Downhill - Freeride
    Last Post: 04-04-2011, 05:24 AM
