Results 1 to 10 of 10
    Reputation: KRob's Avatar
    Does intense powder coat their frames.
    My buddy had been trying to strip the paint of his old 6.6 and was having a devil of a time getting it off..... Especially in the crooks and welds.
    He's tried everything including sandblasting and the stuff wouldn't budge. Someone suggested it must be powder coat.
    I wish my recent frames had paint that durable.
    Isaiah 58:14
    www.stuckinthespokes.com
    Yes, they powdercoat their frames. I'm pretty sure there are some industrial strippers (chemical) that would be helpful to your friend.
    Reputation: trojans1993's Avatar
    Look for a powdercoat specific stripper. Another guy was having the same problem and found something that worked great.
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    Quote Originally Posted by KRob View Post
    Your buddy will need to chemically strip the frame to remove the powder coat. Sandblasting/beadblasting can damage the aluminum. We generally work with Linco Industries in Anaheim, CA- (714) 635-2800
    Apr 2013
    I have also been trying to strip my frame, I have used multiple things including aircraft remover. so far nothing, the aircraft remover will work if you do it 5 times then some sanding but that only kinda works on big surface and not in the little joints and stuff. It works perfect on other powder coated frames I have tried it on but not my spider. How bad is bead blasting for it? i have heard sand blasting is bad but T thought bead blasting was ok so i was gonna try that.
    Reputation: slowrider's Avatar
    I bought a demo Tracer 275 at the Intense parking lot sale, a pink Tracer 275! Which required, for a man as slow as myself, a new color, and according to Intense customer service personell they have a local powder coater they use; they do their own heat treating (equipment purchased from mountain cycle when they went overseas) but not their own powder. Intense use to use Olympic Powdercoat but the task of driving in to orange county to drop off and then pick up frames became too much.
    Olympic charged me $130 to strip and recoat my frame with a slow freindly Dark Charcoal Metallic Green, so don't bother stripping it yourself, you'll spend tons of time trying to get it clean enough for new powder, and expose yourself to some gnarly stuff in the process..
    I had really go luck with the aircraft stripper on my uzzi vp. It took two coats and about 4 hours to get it done. Used a coarse nylon bristle brush for the welds and tight spaces no problem. Used a plastic putty knife for the rest of the bike. That stuff sure is nasty to work with though( use gloves, safety glasses etc., in a very well ventilated area ). Afterwards, I wiped it down with some mineral spirits, then soap an water and was good to go.
    Quote Originally Posted by slowrider View Post
    Thanks. That's good intel there. I just bought a Dayglo Yellow Chilcotin and the paint doesn't seem very durable (already have two or three pretty good chips) so when it gets too bad I'll probably go that route.
    What was the turn around time on your bike?
    Is this the place?
    Isaiah 58:14
    Turn around was one week. I'm at work and for whatever reason the security program won't let me open the link you sent. Olympic is in Santa Ana Ca West of the 55 fwy off Dyer or Mc Fadden.
    Is this the place?
    That's fast. My buddy already got his repainted (gave up on going raw/polished).... but I may use them in the near future.
    Yep that's the place. Thanks.
    Isaiah 58:14
  1. Replies: 15
    Last Post: 08-28-2012, 05:44 PM
  2. Polishing powder coat - what to use?
    By awai04 in forum Frame Building
    Last Post: 02-18-2012, 11:31 PM
  3. Powder coat or other paint?
    By dja4260 in forum General Discussion
    Last Post: 11-20-2011, 02:25 PM
  4. Powder Coat MCR?
    By criticalmass in forum Niner Bikes
    Last Post: 04-03-2011, 03:52 AM
  5. Powder Coat Vs. Wet. Appearance same?
    By smokinjoe in forum General Discussion
    Last Post: 03-22-2011, 06:36 PM
