Results 1 to 13 of 13
Thread: Ccdb on Carbine
    Dec 2010
    Ccdb on Carbine
    Anyone using CCDB on their Carbine?
    Dec 2010
    Anyone?
    I am.....and it's awesome!
    Sep 2012
    wow.... great to know it's awesome!
    Only problem is you can only realistically use the 140mm setting as the air can will bottom against the frame in the 150 setting...certainly on the large size
    Sep 2012
    Really?? If that is the case, the DB air is not an option for me..... makes me wonder if a vivid will do the same.....
    It just touches and no more. Whether it would strike it with any force im not prepared to take the chance so run it at 140 and there is plenty of clearance
    Sep 2012
    Yeah that is the 140 setting in the pic.the top hole is the 150
    Sep 2012
    Yepp, I know, but looking at that it's real hard to see how it could get in contact with the frame.
    I know you wouldn't think. I was tempted to just run it as it is just the slightest contact but not worth the risk I reckon. Especially when u factor in cables it definitely bottoms on them
    Dec 2010
    My question was for CCDB coil.
    Apologies. It's a CCDB air which I have. I don't know about the coil version fitting
