Carbine and XTR M986 RD
Anyone know if this rear derailleur will work on the Carbine, didn't realize I ordered the one that can be direct mounted until I rec'd it. Can it be used in conjunction with a Derailleur hanger or do I need to send back and get an M985?
You got the Shadow plus right?
I've got the RD 986 SGS on my Carbine 275 3x10. Fits perfect.
Great, thanks. Can't wait to set this whole bike up. Putting it on a small Carbine 275, which FD did you use?
For my 3x10...
Shimano"XTR Trail M-981"
Front derailleur, Shimano IFDM981TD6 "XTR Trail M-981"
3x10, direct mount, top-pull cable routing, aluminum
If you run 2x10...
Front derailleur, Shimano IFDM986TD6 "XTR Race M-986"
2x10, direct mount, top-pull cable routing, aluminum
Thanks again, that's exactly what I needed.
Consider buying a spare drive side dropout for the 275.
would it fit on a tracer 29 do you think, also should I get a med or long for running xt 2x10 cranks
Yes, it should fit fine on the T29. The M986 RD mounts to a normal hanger or you can remove the small standard mount extension and use it for direct mount. For 2x10 I would go med cage.
- You may not post replies
- You may not edit your posts
Forum Rules
