Results 1 to 8 of 8
    Sep 2012
    Good job! Carbine: Wheel off center, SOLVED
    Ok, I think this info might be useful for some of you Intense owners.
    I have read some posts where people have problems with the rear wheel being off center and rubbing the seat stay. Me included.
    I got qr at first and found out that they were cut out wrong, after som grinding the wheel was still off center. It seems there is something else wrong as well....
    But, I was supposed to get X-12 d.o, and they came today. To my big relief, the wheel is now in center!
    Check your drop outs !!!
    Dec 2010
    Thanks for the info...could you help me understand what I'm looking for?!?! I have X-12 dropouts and my wheel is offcenter.
    EK2K
    Sep 2012
    Your X-12 is off center, hmm...
    In this picture you can see how my qr looked like. They are supposed to be in line or equal.
    Anyway, grinding down did not help :/
    Dec 2010
    I will check them out tonight...thanks Kamikaze!
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    If you don't mind me asking, what kind of torque are you guys using on the drop-out hardware?
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
    Dec 2010
    So I called intense a while back and asked for the Carbine manual...I was emailed the 2010 manual by them...
    http://intensecycles.co/manual/2010_...llbikes(1).pdf
    It has a torque of 30-45 in-lbs for the "Derailleur Hanger Bolt".
    I checked mine, and they start to spin around 60 in-lbs.
    Hope that helps.
    EK2K
    74 & 29 pilot
    Oct 2010
    Quote Originally Posted by EK2K View Post
    Hope that helps.
    EK2K
    Yeah, that gives me an idea. Thanks!
    UPDATE: Intense said hand tighten them. Before I took off the factory installed dropouts, I started with 6Nm and went up until it turned the bolt; 3 of them moved at 8 Nm and 1 at 11 NM. So I tightened them all to 10 Nm with no problems.
    MTBP
    Sep 2012
    I used blue loctite on mine.
