Hi guys.. I bought a demo Carbine from the lbs ... Just wondering if someone could kindly tell me if the 160mm setting is the top or bottom hole?... Thanks
I use the bottom hole when climbing for at least 500-700 ft verticle or if climbing for long periods of time. It places you a little more forward and over the pedals for more power. Technically you should change the air pressure when going from one setting to the other (different leverage ratios) but I usually will just run the correct pressure for the top hole(descending) which is a little high for getting the correct sag when in the bottom hole but the bike still rides fine. I then change to the top hole when I finally reach the top.
I think intense meant for the bike to be setup using one or the other hole and a corresponding fork.
150mm fork/ bottom hole
160mm fork/ top hole
But I think it also works great to make this bike have two personalities in one ride.
Yeah I'm running a 36 talas on the front, with the rear in the 150mm setting... RP23 set to 1... Seems pretty good so far but always keen to hear what others think works
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
