I'm at about the same, 155 +/- 1 psi, and I weigh 210 lbs geared up. Using the CTD also, and have mixed feelings about it. 155 get me right at 25% sag, but I have yet to knock the rubber ring off the bottom of the shock from drops at 3 feet or less, with speed.
Really?!? I'm at 180psi now!
I'm using almost all the travel just by riding down a staircase (using the upper hole on the link). I don't have the CTD option, but the regular 2012 RP23 Kashima, can it be that different?
Yes, it has a boost valve. The Tune on it is 200 and takes less air for me to get 25% sag, whereas my '12 Firebird with the Factory Float RP23 has a tune of 175 and takes WAY MORE air to give me 30% sag. :madman: My CTD seems really stiff in the Trail medium setting, and just seems like too much switching while riding to get the correct feel.
I really don't know what those #s mean for the BV... I'm running 220 psi in the Firebird; Now it's a different suspension design, different size and has 167mm of squish, so that may have something to do with it also.:skep:
So far I would have to say the CTD feels more controlled than the RP23. I really like the three settings for racing Gravity Enduro. MTB Pilot: What setting have you been running your Trail position in?
I was using 2(med) as I thought that was a base and you could make it softer or firmer, but it seems that I need to use 1(soft) to make it not feel harsh on the normal rocky trails here. I noticed when I first got the frame, after letting the air out of the shock, that the new mounting hardware felt a little stiff. Thought it was supposed to be less friction, but maybe it needs time to break in. Since getting back on the bike a week ago, I have about 50 miles of super rocky and technical climbing and descending here in Phoenix. I don't mind flipping the switch between trail and climb for the longer climbs, but the ups and downs come quick in some places and having to flip to the descent mode from climb and trail, is kind of annoying and inconvenient. Maybe I'll just get used to it eventually.
Please verify which hole, top and bottom, gives you 6" and 5.5". I think I'm confused:madman:
I'm 82kg geared up, upper holes in the link (6-inch travel position), running 160 psi with the new plastic low-friction bushings. Only bottoms out on the biggest of hits.
K, this might not be so bad anyway. I believe I'm running 180 psi now, and I'm a good 10kg heavier.
I did some hard landings and did bottom out, which is ok, but I think I should check again during lighter terrain. Riding fast down a stairs is rather brutal for the shocks. I'll try 190 and 180 next time and check again. It's also something about getting used to a new bike and shock as well.
@MTBpilot...I called Intense on this, bike comes setup from Intense in the 5.5" position (lower hole). Moving to the upper hole (closer to top tube) gives you 6" but requires more shock pressure...more leverage on the linkage?
I moved it up to the 6" hole and am using about 185 PSI now for proper sag. It does feel more plush in all settings.
I'm thinking about buying a 2012 RP23 BV with the simple "propedal" switch and maybe a remote. This whole reaching down to switch between three different settings on AZ trails is VERY hazardous to my health. Would I need to send it to Fox to get the proper tune that Intense spec the Carbine with, or will I not really notice a difference.
I like the way the bike climbs in the climb mode, but otherwise it feels a little inefficient. No big deal to switch it to climb, but after I crest the top of a big climb and start down, I sometimes forget to switch out of climb and it's way too harsh on the descent. I was spoiled with the Firebird and DW Link, as the propedal made no difference and the DWL kept the climbing efficient.:madman:
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
