Results 1 to 3 of 3
    Sep 2012
    Carbine, link bolts unscrews
    I have even used blue loctite, but they still unscrew. It's so bad I have to tighten them during each ride! Any tips?? Red loctite??
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    Quote Originally Posted by Kamikaze911 View Post
    Something you may want to try is adding a generous amount of blue loctite (we use #243) to the threaded part of the top link and frame themselves, not the actual bolts. Putting loctite onto the bolt only can cause a lot of it to be lost on the bearing as it is inserted. Also, the torque value for the shoulder bolts is quite high- around 175 in/lb (19-20nm). Make sure after you apply the loctite to tighten the bolts appropriately, and then give the loctite adequate time to dry.
    Give this a try and let me know how it works!
    Feel free to email me with any other questions- sam@intensecycles.com
    Sep 2012
    Thanks, can't complain about the response time !
    Great stuff, I'll give it try as soon as I get the right loctite.
    Maybe I'll finally get a torque wrench too....
    I'll let you know
  1. Replies: 18
    Last Post: 01-20-2015, 09:53 AM
  2. Undoing Lower Link Bolts on HD
    By Trackho in forum Ibis
    Last Post: 03-06-2013, 02:52 PM
  3. Replies: 1
    Last Post: 02-28-2012, 08:14 PM
  4. Rear suspension-link bolts 09' Fluid LT
    By AndesJack in forum Norco
    Last Post: 05-30-2011, 04:52 PM
  5. 6.6 SS - Link bolts and washers
    By hafnz in forum Intense
    Last Post: 03-05-2011, 08:34 PM
