Results 1 to 6 of 6
    Ambi-Turner
    May 2010
    Carbine 275 Newbie Questions - Intense Retailer Clueless
    My bike has the shock mounted in the lower position. Is this the 5.5" or 6" setting? Owner's manual won't download from Intense site and local Intense bike shop not sure.
    Also, how much will the bb drop if I use 5.5" setting and 140mm fork compared to using 6" setting and 150mm fork?
    Reputation: OCMoto's Avatar
    Upper hole is 6", lower is 5.5". Not sure on the BB height change with the different forks.
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    The BB doesn't move when you change the travel setting on Intense bikes. Only the fork axle-to-crown would change it. You'd have to do some trig to calculate by how much, or use the Linkage program available at Bikechecker.com.
    Dude, got any schwag?
    Reputation: TheSchwagman's Avatar
    As stated before, the rear shock setting does not change any angles or BB height. According to the good folks at Fanatik Bikes, a Carbine 27.5 gets a 13.7" BB with a 150mm fork, and 13.5" with a 140mm fork, so 2/10" difference. Understand that these numbers are with the bike unladen with ballast (rider), and shock pressures can be adjusted slightly to get the perfect ride & geometry for each individual rider. Fox designs their shocks and forks for 25% sag. If you toss your bad self on the bike, with 25% sag +/- 5%, you could see 12" to 12.5" BB height on the trail.
    Billy
    Speed is sweet, it's like an avenue to
    ... Shredtopia!
    Ambi-Turner
    May 2010
    Thanks guys. The shock is in the lower mount and I'm getting 13.8" bb height with revelation 150mm fork and Schwalbe NN 2.35 tires. My old bike had a much lower bb, so I'm looking to lower this one. I'm only about 135-140lbs with riding gear, so low air pressures don't really produce much sag, although I manage to use all the travel on most rides Although running a 140 fork won't reduce it much, I could also get a travel adjust fork that would lower it even more and help with the steep climbs.
    Take 5% out of the pressure (F&R) and report back to the group.
    Either that or go on a Homer Simpson doughnut-only diet and put some weight on. ;o)
    Oh yeah, and ADD PICTURES.
    Billy
    ... Shredtopia!
  1. Oh hello Intense Carbine 27.5....
    By hammerheadbikes in forum 27.5
    Last Post: 08-05-2013, 03:01 PM
  2. Intense Carbine 27.5
    By Ridnw/bear in forum 27.5
    Last Post: 09-14-2012, 12:55 PM
  3. Intense Carbine review
    By jaffro1 in forum Intense
    Last Post: 07-29-2012, 07:04 PM
  4. Completely clueless wheelset questions...
    By Colo Springs E in forum Wheels and Tires
    Last Post: 10-10-2011, 03:57 PM
  5. intense carbine
    By invol2ver in forum Intense
    Last Post: 08-12-2011, 05:57 AM
