    Nov 2007
    Carbine 275 - Flip seatpost collar 180 degrees?
    My new dropper post has the cable exiting in the back. Now in the "normal position" as I have the post quite far stuck down, it means the cable will intefere/bend badly as the bolt of the seatpost collar forces it away.
    If I turn the collar 180 degrees it is perfectly fine. Now I just want to be sure there is no risk this puts extra stress on the frame? As far as I can see the seatpost tube is cut both front and back and the collar has a straight cut so no fancy offset cut. So flipping it shouldn be fine but just wanted to be sure
    Would like to know that to. thx
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    Not a problem to go 180 degrees. You can run the collar forwards or backwards, just not to the side.
    Sam Wilson
    Things & Stuff Specialist
    Beer Drinker
    Intense Cycles, Inc.
  1. '13 Trail 29 SS seatpost collar?
    By deuxdiesel in forum Cannondale
    Last Post: 04-29-2014, 03:07 AM
  2. Seatpost collar: Canti?
    By FNFAL in forum Cyclocross
    Last Post: 05-22-2013, 06:30 PM
  3. THOMSON Seatpost Collar
    By prepsheriff in forum Beginner's Corner
    Last Post: 06-25-2012, 04:41 PM
  4. Need a non-slipping seatpost collar
    By loggerhead in forum Weight Weenies
    Last Post: 02-21-2012, 10:46 AM
  5. Pugsly Seatpost Collar 30.0 or not?!
    By dustyduke22 in forum Fat bikes
    Last Post: 11-03-2011, 05:44 AM
