Results 1 to 10 of 10
    Reputation: manchvegas's Avatar
    Mar 2011
    Carbine 27.5 manual... grease zirks etc..
    Hey, bought a 2013 carbine.. noticed it didn't have any grease zirks but had just blank plugs in the pivot bearings... anyone know what size will fit? And do people leave them in while riding, or put them in, grease it up, an then put the plugs back in? Kinda confused. Manual online at intenses' website is coming back as "page not found" as well.... hope to post pics of my build soon.. thanks in advance..
    Full time rider part time racer...
    See my adventures here..
    https://www.instagram.com/projectnortheast/
    There is a little adapter that fits into your grease gun that has a pointed tip that pushes grease through the middle of the "plug" you mentioned. (It isn't a plug!)
    Anyway, if you don't have the piece, you can always get a syringe, fill it with grease, and then take the "plug" out and force grease in through the remaining hole.
    Contact Sam and see if he can send you the fitting/adapter.
    Mar 2011
    does anyone have sams contact info?
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    Quote Originally Posted by manchvegas View Post
    Shoot me an email today if you have a chance!
    Sam@Intensecycles.com
    Mar 2011
    sent you an email with pic sam.. any idea when you guys will have the manual available online? as of right now, link is broken.... tried from multiple computers... would like to look at it for service etc.. also to see which hole in the rear link is for 140/150 travel etc....
    kneecap
    Upper hole -150mm travel, lower hole- 140mm travel. Can't help with the zirks, mine have a small hole (there's that word again) in the center of the zirks for a grease needle...
    Mar 2011
    gotya, thanks kneecap.
    May 2013
    This is what you need:
    Performance Tool W54216 - Grease Gun Needle Adapter | O'Reilly Auto Parts
    It pushes grease past the tiny ball bearing in the center of the zerks installed on the frame.
    I got mine at O'Reilly Auto Parts. Had to mess around with all the little adapters to get the needle to fit on the mini grease gun, but it worked fine once we figured it out.
    Mar 2011
    cool, I'll give it a shot...
    kneecap
    I'm sure you've thought of it, but I used a Q-tip to clean the fitting & the ball before pushing grease into the bearings.
  1. 275 Converted Carbine vs. Carbine 275
    By jtforester in forum Intense
    Last Post: 05-28-2014, 03:28 PM
  2. Pressfir BB prep - grease, no grease, locktite, etc?
    By TechniKal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2013, 08:51 AM
  3. Replies: 8
    Last Post: 09-07-2013, 10:22 AM
  4. What Type of Grease for Grease Ports?
    By B-Line in forum Santa Cruz
    Last Post: 10-28-2012, 05:06 PM
  5. Grease gun and grease recommendation
    By wonny in forum Intense
    Last Post: 10-17-2012, 11:35 PM
