Thread: Cable rub
    kneecap
    New question here. Cable rub
    I run a 3X9 XTR on my carbine. When in the long travel mode the tire rubs, heavily, on the front derailleur cable under full compression.
    Any solution, other than 1X?
    I ride the road to trail systems regularly, & like my current gearing range.
    Helpful hints appreciated, Thanks, Kit
    Post a pic of your cable routing.
    It sounds like he is using the left side cable posts and it is wrapping behind the seat tube. Change it to the right side and run it over the linkage. I had the same issue with mine and this is how I fixed it.
    kneecap
    Hey,thanks that's the way I'm currently running the cable. Nice curve to the derailleur & it shifts well. I'll try your suggestion today
  1. Naked Shifter Cable or Full length Cable Housing?
    By Scott Novak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 04:02 AM
  2. Replies: 1
    Last Post: 04-16-2013, 06:20 AM
  3. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  4. 6mm Gear cable ferrules and suitable cable?
    By Rick Draper in forum Vintage, Retro, Classic
    Last Post: 09-23-2012, 02:01 AM
  5. QBP cable housing $1/ft; Sram Derailleur cable $2/set; free ship over $30
    By bob13bob in forum Where are the Best Deals?
    Last Post: 03-29-2012, 06:51 AM
