    Bolt torque and greasing question
    Hello all,
    I have recently purchased a used tracer 29 frame. It's a bit of a gamble as i have never ridden a 29er! Anyway, I don't have any information regarding bolt torque settings so if anyone can help it would be appreciated.
    Also, is there a procedure for greasing the bearings or is it just a case of pumping it in. Don't know if the idea is to 'flush' old grease out by loosening the outer bearing caps.
    Thanks in advance.
    遅すぎ
    Email Sam, he will hook you up with the torque specs.
    sam@intensecycles.com
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    MattZo, did you get the torques? If not, PM me and I'll send you the Intense "all bikes" manual that doesn't seem to be online anymore.
    CTB
    CTB is offline
    Oh, and as for the grease: Don't loosen anything, just pump grease into the zerk fittings until you see fresh grease oozing out at the links. At least that's what I've learned as of late - I need to start doing that on mine, as I've just installed new bearings since the old ones were shot.
  1. Over torquing and greasing the Bio-centric bolt
    By ozzybmx in forum Niner Bikes
    Last Post: 06-09-2012, 03:22 PM
  2. 2008 El Guapo bolt torque?
    By 8shadow8 in forum Titus
    Last Post: 08-26-2011, 12:31 PM
  3. Element MSL/RSL bolt torque spec
    By leggatt in forum Rocky Mountain
    Last Post: 05-07-2011, 12:20 PM
  4. Linkage greasing question
    By 2planker110 in forum Intense
    Last Post: 04-18-2011, 12:52 PM
  5. Fun Bolt Torque
    By half_man_half_scab in forum Wheels and Tires
    Last Post: 02-07-2011, 10:08 AM
