Results 1 to 3 of 3
    Reputation: vice grips's Avatar
    Dec 2012
    951 off set bushings?
    Im building my wife's 951 and putting a totem fork on. I would like to slacken the ht angle. Does any one know what size off set bushings or where i can get them? It's the 26 wheel version with out 3G dropouts and has a cane creek dd. will post pick when I am done thanks
    Once you go slack, you never go back!
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    Quote Originally Posted by vice grips View Post
    The sizing you'll need is M8x34mm (forward) and M8x41mm (rear). Not sure who makes these at the moment (burgtec?), but my suggestion would be an Angleset instead if you're looking to adjust the head angle
    Sam Wilson
    Things & Stuff Specialist
    Beer Drinker
    Intense Cycles, Inc.
    Sam@Intensecycles.com
    Quote Originally Posted by Sam-IntenseCustServ View Post
    I'll second this - I had a 26" 951 with the G3 rear end, running it in the middle position. I had the bike built with a Totem SA 180mm fork on the front and a -1 degree angleset and it was brilliant! Super fun build, go for it!
  1. Replies: 2
    Last Post: 01-10-2014, 01:56 PM
  2. Bushings
    By carl211 in forum Bike and Frame discussion
    Last Post: 01-09-2014, 02:51 PM
  3. DU bushings - where to buy
    By freeriderB in forum Downhill - Freeride
    Last Post: 01-16-2012, 09:46 AM
  4. bushings
    By tunajuice in forum Rocky Mountain
    Last Post: 11-15-2011, 09:52 PM
  5. Where to buy bushings
    By kjsayers in forum Yeti
    Last Post: 10-30-2011, 09:30 AM
