Results 1 to 6 of 6
    Wait for me!
    Reputation: whoopwhoop's Avatar
    Nov 2008
    951, help me trim some fat
    Looking to put my 951 on a bit of a diet, I'm wanting to make it a little more playful and bike park friendly. Currently it's sitting at about 41 pounds, I'd like to get it down to the mid 30's. It currently has Azonic Outlaws setup with tubes, I'm planning on getting some lighter tubeless wheels, so that should cut a few pounds right there. Going from the stock DHX RC4 to something air sprung should yield me about a pound savings as well.
    Here's the full build spec as it sits now, if you see anything that could be easily swapped to trim some fat it would be much appreciated
    • Frame - 951 (L)
    • Shock - DHX RC4
    • Fork - Fox 40 (coil)
    • Wheels - Azonic Outlaws setup tubed
    • Stem - Funn direct mount
    • Bars - ODI flight control with wingtip extensions
    • Brakes - Saints all around wth 203 rotors
    • Crankset - Truvativ Descendant w/ 38t ring
    • Drivetrain - Zee 10 speed with 11-28 road cassette
    • Seatpost - Thompson Elite
    • Seat - Funn (not sure what model)
    Aug 2010
    Quote Originally Posted by whoopwhoop View Post
    • Frame - 951 (L)
    • Shock - DHX RC4
    Wheels are the best place to lose weight... rotational mass will have the biggest impact on the ride... you could also go to an air fork/shock but the cost/benefit decreases. Getting it down to the mid-30s will cost significant $... I had my 951 down to 34.5 lbs but it cost a bit.
    Wait for me!
    Nov 2008
    Quote Originally Posted by gretch View Post
    Thanks for the info. Would you mind listing the spec on that bike? Curious to see how you had it built up
    Aug 2010
    I will try from memory... I have a M9 now, but the builds are similar:
    Frame - 951 (L)
    Shock - CCDB Air
    Fork - RS Boxxer WC
    Wheels - Easton Havoc 150 UST
    Stem - Easton 35
    Bars - Easton 35 alu.
    Brakes - Shimano Zee
    Crankset - Raceface Atlas
    Drivetrain - Zee 10 speed with 11-34 cassette
    Seat - Selle Italia SLR
    Here's a pic:
    Wait for me!
    Nov 2008
    Frame - 951 (L)
    Shock - CCDB Air
    Fork - RS Boxxer WC
    Stem - Easton 35
    Here's a pic:
    How did it ride with the DB air? I have one on my Mojo HD and I love it, I'm thinking the dw link vs vpp would behave pretty similar
    Aug 2010
    Actually, the DB Air was not recommended for the 951 due to the leverage ratio of the suspension. It made it impossible to get full travel due the progression. This may not be an issue now with the XV air can being available. I would check with Intense or a suspension tuner to get their opinion.
  1. Air shock fork recommendations?
    By bubbascrub93 in forum Shocks and Suspension
    Last Post: 03-26-2014, 02:45 PM
  2. New rear shock recommendations
    By MrSpecialK in forum Shocks and Suspension
    Last Post: 05-16-2013, 01:13 AM
  3. WFO Rear shock Recommendations?
    By gregD in forum Niner Bikes
    Last Post: 03-13-2012, 07:20 AM
  4. DH shock recommendations please
    By genemk in forum Downhill - Freeride
    Last Post: 11-03-2011, 12:25 PM
  5. Shock Upgrade Recommendations
    By bikerghan in forum Shocks and Suspension
    Last Post: 01-17-2011, 04:58 AM
