This time I tried the SS with a pike and DHX-air.
The bike is 15.1 Kg' = 33.29 lb
I can make them lighter without loosing strength up to 14.5 kg' = 31.9 lb.
For the meenwhile the geometry feels best with the pike, The ride is fast and nimble, no problem to jump, at the trail its great and except loosing some plushness its perfect.
Nice looking build and you definitely got it light. I wonder how you'll like the max 520 A-C and the accompanying BB height over the long run. I've found that for rougher trails that I really needed the 545 A-C of the 36 even if I didn't need the accompanying 66.5 deg HT angle just to get the BB to a manageable height. And this is in the context of someone who is very used to low BBs. If you spend more time on flowy, smooth trails and jumps, this may not be an issue. Just thinking out loud. Good to see some more SS's getting built up. I really need to post a pic of my build.
Actually there where no problems with the low BB except few times in turns I touched some rocks but I am sure in next runs it won't happen.
I used to ride the Blur 4X, this is now like the 4X on steroids.
the BB height from the center of the BB to ground is 13.45"
I ride in a very rough train and I tried the SS with all the A-C that are possible and I found that for me the Pike is good enough I am sure I can found a better fork then the Pike but for now I will keep it.
The head angle looks right on the spot, but i guess that if you add some front sag to the equation, a Lyrik might be better for the HA and the BB height as well..
The weight of this beauty is amazing, about the same as my aggressive HT...
I picked up a nixon thats 3 lbs lighter than my travis, its the 145mm and I think the a-c is 518mm or something, with the king hs it should raise it up to about 532?? I'm hoping for a new wheelset with king ISO 150mm rear hub and 819s that would be something around 1800g. Still, wouldn't be as light as yours, thats a beauty!
