Results 1 to 36 of 36
    6.6 Slope Style with 888
    I just finished 3 hours run DH/Trails in the desert.
    I tried the bike with 2007 888 SL,
    Most of the time on 160 mm' and some DH parts with 180 mm'.
    the A to C is 54 cm' on the 160.
    Sorry for the dust on the bike, tomorrow I am gonna do another run and then I will be able to write my Feedback (with better pix)
    Im a Cowboy
    Reputation: CrustyOne's Avatar
    Oct 2007
    Any good then?
    DON'T TELL ME I'M STILL ON THAT FECKIN' ISLAND! ....
    Reputation: Ghaleon109's Avatar
    Haha, thats badass.
    Literaly a mini Socom
    Death By Snoo Snoo
    Reputation: munkyspank's Avatar
    180mm setting
    at the 180 setting does it feel pretty slacked out? to the point of inefficient climbing? Also, the SL is air right? how is the Air Front/Coil back feel?
    rain rain go away...
    Reputation: peachy-B's Avatar
    apologizing for the dust on the bike? huh? never!
    OK second day today,
    same course a bit different setup.
    I bought the bike for my trails and "fun" rides, I have experience on most of Intense bike.
    I was looking for light, nimble and easy to handle bike.
    I don't do SS or dirt, but our trails are rough you can see in NWD8 parts of it.
    Yesterday it was my first ride on the SS, when I put my bottom on them I thought to myself
    how similar they feel to the Socom.
    The bike felt good, lot of confidence and firm.
    17.8 kg' withe 888 SL and some old stuff I had at home
    After I will learn what is best to the bike I will buy the right components.
    The only problem I felt was that the bike didn't roll, it wasn't intense feel, like something is stopping the bike.
    So I swapped the wheels and rotors and changed the stem from 50 to 70,
    That solved the problem.
    With the 888 the nose was to heavy but I got used to it and felt good
    I think I will get the Fox 36 Float for the bike.
    Yes the 180 is too much for the bike I didn't like it that way
    About Air fork and Spring shock, I cant see any problem with that But I need more time on the bike, any way next week I am gonna try the DHX-AIR on them
    Some pix from the ride,
    I dont have the SS in action becous when I ride I cant shoot
    Attached Thumbnails Attached Thumbnails 6.6 Slope Style with 888-dsc_0805.jpg
    Some more pix
    Reputation: drumstix's Avatar
    Nice pic's! Swaping out parts? You would make a great homer!
    I would like to hear your thoughts about the SS with the air forks and shock.
    Yamaha & Paiste, weapons of mass percussion
    I had a short ride with 140 pike 454
    It felt very good except that it was hard to lift the front,
    I had to push harder on the pedal.
    I have got the feeling that a shorter fork will not be bad for the bike
    Reputation: FreerideMonkey7's Avatar
    Oct 2007
    you have a sick place to fide and a sicker bike
    how about getting a totem 2 step or a 66ata
    or go smaller with a lyric or 55ata?????
    Reputation: iRider's Avatar
    Quote Originally Posted by esku
    Just curious, what problems did those rotors cause? Aren't those the Braking/Aztec? Do you have weights for the 203 mm front and the 185 mm rear?
    BTW: nice bike and awesome trails!
    Quote Originally Posted by iRider
    As I mentioned before, the component's on the bike is some stuff that I had at home,
    So I took an old saint brakes with Stuns wheel set from another bike and so on,
    The Braking rotors are a bit wider so they touched the brakes pads,
    But I think that most of the problem did my rear hub the Hope PRO 2, I just changed the axle from QR to a 10mm' and I think that i closed it too strong...........
    I don't have weights of the rotors but I must say that I think that the braking are the best rotors around,
    Its shame that its so hard to get them these days
    Reputation: theDoubleD's Avatar
    Nov 2006
    i love the 6.6 SS. i would love one those! does the SS still maintain its climbing capabilities?
    Reputation: sanjosedre's Avatar
    I have been climbing quite a bit on mine & it feels fine. You will need to have a very long post as the frame sits very low.
    Reputation: Downhilldoug's Avatar
    Mar 2006
    Maybe a GD for SS ?
    How low is low it looks like you got a lot of seat post out of the frame what size you running?
    I wonder if a gravity dropper would fix the low frame thing and you could raise it when its time to ride back up and slam it down when it time to rip.
    actually I don't see any seatpost issue
    a 41 cm' post will do the job
    mine is 27.2 with a reducer
    Im a Cowboy
    Oct 2007
    esku..what headset you using?
    Quote Originally Posted by CrustyOne
    That one is the Dabomb 1.5/1.1/8 but I am waiting for the syncros FBI.
    Oct 2007
    esku, will the 41cm seatpost go all the way down? If not what range of adjustment does it have? what if it was a full size diameter?
    thanks
    Quote Originally Posted by pipe
    thanks
    The one I use right now is 350,
    It gets full in and there is at list more 5-7 cm', so I think 41 is OK
    This is 27.2 seat post with a reducer.
    In few days I will get the 31.6 Thomson so I will have a more accurate answer.
    Oct 2007
    Ok. Cheers for that. I look forward to the update. I only get 4" with my Uzzi using a 31.6 though I could get it reamed out a bit deeper. I was thinking of running the reducer to get around the reaming issue because the seat tube is tapered further down and the wall thickness maybe a problem.
    Hey Esku, do you know what the Bottom Bracket height is with the Pike at 140mm travel?
    Quote Originally Posted by aye-aye
    the BB height from the center of the BB to ground is 13.45"
    thanks esku
    What one could do is use a 160 coil Lyric, that way you can have the low 140mm travel settings like the Pike and the 160mm settings for the DH stuff.
    yesterday I had a DH run with 66 RC2 ETA at the front .
    It was great, it's hard to tell what is better the Pike or the 66,
    With the Pike the bike is light fast and nimble,
    it feels like a BMX with suspension, a real FUN bike it's pedal well at least as good as the 6.6.
    With the 66 at the front the bike become more of the serious side, like the VPX or the SOCOM/M3, you can feel that the bike can move the mountain.
    It's still a lot of fun but more on the heavy side,
    Pedal well jump very good and fusttttttttttttt.
    I don't know why but it feels better with the 66 then with the 888 SL although its the same A to C, maybe because now I have a better feel of the bike then the last time I rode with the 888 SL.
    I didn't have the chance to try the VAN I think that the Van or the LIRIK will be the best compromise for the bike.
    Dec 2005
    hi esku,
    was that a 2006 (170 mm travel) or 2007 (180 mm travel) Marzocchi 66 RC2 eta?
    Cheers
    Quote Originally Posted by Zuzi
    hi esku,
    Cheers
    It's 2007 180 mm travel
    I had a nice DH/Trail run today and the bike felt so flush with the 66 almost like the M3
    Dec 2005
    thanks esku, happy trails!
    Hey esku
    Could you so kindly provide the bb height & HA with the Marz 66 setup ?
    Thanks in advance!
    Quote Originally Posted by sanjosedre
    Sorry for the delay,
    It's 13.5", but the sag is around 30% in the shock and 10-15% at the fork. so when you ride the real height is much less.
    Seatpost ream
    Pipe, I had the exact same issue, opened a post on hear actually and got some advise. To rectify the problem, I looked down the seat tube with a torch an noticed several small bures (spelling?) I turned the frame upside down and carefully took a curved metal file to the inside of the seat tube (upside down so the filings didn't end up in the bottom bracket area). I then used a vacuum cleaner t suck out the loose filings wrapped some damp kitchen roll around a 27.2 seatpost and inseared it to remove the remaining metal filings, then used dry kitchen roll in the same way to dry. I slightly greased my 31.6mm x 410mm Thomson seatpost and tested it. It now goes in almost all the way (phew!). The tapering you talk about appears to only be on the outside of the seat tube, so if you are careful to just remove the slight bures, I think you'll be fine. I was going to go down the shim and 27.2 route, but I don't trust it (may just be my paranoia).
    Hope this helps, good luck!
    Apologies all, as I realise this this post is completely unrelated to 6.6SS with 888, however hopefully it may help others with Intense seatpost issues.
    hi ESKU, sorry, but what size is she and how tall are you? are you a regular in body size? SHE'S Indeed AN ANGEL....!
    Quote Originally Posted by jdj_sasha
    I am REG' in my body size
    I am 180 cm' tall
    and she's M
    Reputation: Mikey_C's Avatar
    Mar 2005
    first off...thats for being the test monkey for forks on the ss. thanks for the effort and great info.
    i was leaning toward a vanilla after riding an 07 66rc2x and though it was just a bit too much fork for me. Its what what you mean about your comment above?
    I was leaning toward the vanilla as this point but contemplating an adjustable option for more versatile rig
    Ordered my ss last week..no i just gotta decide on fork/headset combo(in theory im planning on using parts i have laying around to build her up)
    Hi
    The 66 is one of the best forks I ever ride,
    If you gonna use the bike mostly for DH rides then I think that the 66 (or the Totem) is the best combo with the SS, but I think that for DH is better to take the M3/M6, so its useless.
    I found the SS as a great trail bike and as one its better handle it with a lighter and shorter fork, actually the best "trail" feeling I had with the Pike but some times you need the extra travel so the 160 is more "right" for the bike, I have the ETA on the Z1 and I never felt that its needed.
    For me the VAN supposed to be the best deal (although the Z1 light is not bed at all).
    I use the 32 Vanilla on my P-7 and loves it more then the Talas or the Float or the Pike.
    I have a friend that got the Lyrik and likes it a lot so I am sure that its as good.
    I hope that helps you
