Page 22 of 22 FirstFirst ... 12 18 19 20 21 22
Results 526 to 542 of 542
Thread: 6.6 Photo Album
  1. #526
    And last but not least, mine:
    More pictures at: Intense 6.6 « espritoutdoor
  2. #527
    Nice light-weight build you got there! How light is it with your current configuration? That thing must love to climb!
    Glad to know I'm not the last guy on a 6.6!
    :: Titus FTM :: Santa Cruz TallboyC :: OnOne 456evo2 ::
  3. #528
    As depicted, 14,1Kg, and it is mountain proof. I once managed to build it at 12,8Kg.
  4. #529
    Reputation: delihustler's Avatar
    This is mine
    In action at a gravity enduro a few weeks ago
  5. #530
    Quote Originally Posted by ldonnay View Post
    14.1 kg is very Impressive! Specially since you're still running a dropper at that weight. Mine is heavier and I'm not even running a dropper!
    Running coils at both ends does have it's disadvantages.
  6. #531
    Reputation: deesta's Avatar
    Here's my 6.6 Just built it up...
    I've just finished building my 6.6 up. Here's the list of components:
    FRAME: Intense 6.6 Medium, Raw finish
    REAR SHOCK: 5th Element 500lb spring
    FORK: Fox 32 Float 150mm 15QR
    WHEELS: Hope Pro2 on DT Swiss 5.2's
    BRAKES: Hope Tech M4 203mm front, 183mm rear floating rotors
    SHIFTERS: XT 10sp
    CASSETTE: XT 10 sp
    DERAILLEURS: XT (2 x 10 front)
    CRANKS: XT 175mm
    STEM: Thompson X4 Elite 50mm
    BARS: Easton Monkeylite carbon
    SEATPOST: Easton EC70 Carbon
    SEAT: Crarge Spoon Ti
    PEDALS: XTR SPD's
    F TIRE: Maxxis Minion 2.35
    R TIRE: Maxxis Ardent 2.35
    Has had new stickers fitted by previous owner but they are 'Spider' stickers..
    Weighs in @ 28lb with pedals (on bathroom scales so not super accurate)
  7. #532
    Rebuilt 6.6
    I had a medium Red 6.6 since 2007, but I've never posted it up. Like Gravity Freak, I decided I needed a large. This one came up second hand, and I've had it repainted.
    Spec is nothing special, only things of note, 1 degree angleset cups top and bottom, CCDB, and Spinergy Wheels.
  8. #533
    Here's an update on mine:
    Resprayed and quite a bit of component change and it's so much better...
    Now has:
    Fox Vanilla 36 RC2's
    Tuned 5th Element Coil with off-set bushes
    XT Shadow + rear mech.
    Hope Pro3 AM4 with Flow wheels
  9. #534
    TC3
    TC3 is offline
    Reputation: TC3's Avatar
    My good old 6.6 with Push Van-R and I-9 wheels
  10. #535
    dnd
    dnd is offline
    Hello, guys!
    Oldie but goldie. Still own my Intense 6.6 but has an issue with chain guide. MRP system 3 didn't fit with BB -> ISCG Old adapter. Chainline and roller has a huge gap between. Need an advice. I bet any BB-mount giude will fit well? Or i should choose any 2-ring compatible guides so the roller will slide the way i need?
    On-topic photos:
    PS. Oh, well, the setup is all-round chris king
    cranks - Shimano Deore XT M771 Hollowtech
    Drivetrain is one-ring 36t in front and SRAM X0 11-32 rear.
    Weights 13,7 Kg.
  11. #536
    6.6 Photo Album
    I used a BB 2 chain rings guide from Shaman Racing (carbon), where the slide of the pulley indeed enables the right adjustment.
    Envoyé de mon iPhone à l'aide de Tapatalk
  12. #537
    dnd
    dnd is offline
    Ooook! Thanks, mate!
  13. #538
    I used a blackspire stinger for dual ring cranks (bb mount) with mine.
    then I tried the c-guide and it had a lot less chainslap and much lighter weight. I did notice a little bit more drag specially if the chain ran dry after a few dozen miles.
  14. #539
    dnd
    dnd is offline
    Quote Originally Posted by StanSuarez View Post
    Thanks for a useful suggestion!
  15. #540
    Update to mine.
    Updated a few bits.
    PUSHed CDT rear shock
    170mm Lyrik RC2DH
    KS shown now replaced with a Thomson Dropper
    1 x 10 with Zee/XTR/RaceFace
    DH Mode DeeMax wheels
  16. #541
    The old candy red was starting to get a bit worn so thought I'd go for something completely different. Now Sulphur Yellow with a gold flake. It's much brighter in the flesh and the flake looks great in the sunlight. Just waiting for the decals to arrive...
  17. #542
    Jul 2015
    Intense 6.6 in Kawasaki green
    Fox Talas 160mm forks
    Fox RPL rear shock
    Mavic xm317 rims
    Maxxis high roller/minion tyres
    Race Face atlas crank
    Sram x9 shifters, chain & rear mech
    Hope (purple) pedals, spacers, seat clamp
    Hope (purple) tech e4 brakes
    Hope (clear) grips
    Hope (black) pro evo 2 hubs
    Braided hoses
    SDG seat
