Page 2 of 6 FirstFirst 123456 LastLast
Results 101 to 200 of 542
Thread: 6.6 Photo Album
  1. #101
    Reputation: TrashBike's Avatar
    From Intensecycles.com...
    Quote Originally Posted by soona
    Hi All Intense 6.6 owners,
    Is it true that Cane Creek Double X series Headset will demage the Head Tube?
    Does it include Cane Creek Double XC headset?
    Because i just put a new Cane Creek Double XC on my new intense 6.6?
    If it is true, i will replace it with FSA headset?
    Please advise.....
    This from Intense's website:
    Some observations on the One Point Five interface standard:
    1. The One Point Five standard defines the diameter and tolerance for the bore in the head tube – the standard specifically does not cover the diameter of the headset cups – to quote from the standard drawing, ”HS CUP OD NOT SPECIFIED”. The diameter specified for the head tube is 1.9516” – 1.9532” (49.57mm – 49.61mm).
    2. As manufacturers are free to define their own requirements for the cup OD, both the requirements and the actual parts tend to vary. Cane Creek specifies an OD of 1.9567” – 1.9579” (49.70mm – 49.73mm). We have had experience with two Cane Creek Double Xc Flush headsets causing the head tube to crack on the 6.6. These cups measured 1.9579” to 1.9585” (up to .0006” over Cane Creek’s high limit tolerance). It should also be noted that the Cane Creek is a “deep” headset (20mm vs. 10mm insertion depth).
    3. Here at Intense, we tend to use the FSA Orbit Z 1.5R in this application. Although the FSA drawing allows the OD of the cups to be 1.9547” to 1.9587” (49.65mm – 49.75mm), the units we have measured run 1.9545” – 1.9565”. The insertion depth of these cups is 10mm. We have had no problems in using this head set.
    4. Standard engineering practice for a locational press fit for this diameter part is to have .0004” to .0020” interference. While the actual size of the FSA sets as compared to the 1.5 Standard head tube diameter yields an interference of .0013” - .0049”, the larger Cane Creek sets come in at .0047” - .0069”. We are very concerned that the additional interference is causing undue stress in the head tube material.
    5. Due to the above concerns, Intense Cycles strongly recommends against using any headset with an OD above 1.9565”. This specifically refers to the Cane Creek Double X series, as well as any other head set creating an interference of .0050 or larger.
    Phil Stromg
    Intense Engineer
  2. #102
    Apr 2005
    Nice 6.6 in works finish
  3. #103
    Reputation: OneBikeGuy's Avatar
    Nov 2006
    Hi, I'm getting small size frame, too and wanted to ask you a question.
    I see you use FSA headset and how is the clearance on the fork crown and the downtube?
  4. #104
    31.8lbs with DHX coil.
  5. #105
  6. #106
    Hi,
    I am considering the coil... how do you like it so far, and would you use this if someone handed you a air?
    Quote Originally Posted by king2005
    Hi,
    It was a voluntary choice, after a test with the DHX air. I use my other bikes for other purposes; a Ti Dean for short rides, a light (23lbs) Burner for raids, and this Intense for Alpines rides.
    The coil is amazing in such conditions...
  8. #108
    my 6.6
    2006 Intense 6.6, 2006 Marzocchi All Mountain 1, Avid Cable disc brakes, Thompson seat post, Kenda Nevagal tires, Shimano drive train, and other uninteresting stuff.
  9. #109
    Quote Originally Posted by kjetil
    *Frame: Medium Works 6.6
    *Rider weight: 72kg
    *Rider height: 181cm
    *suspension: 07 Fox Van 36rc2/4-Way Swinger (waiting for DHX Coil)
    *brakes: Formula ORO K24
    *cranks: XT M760 triple 44/32/22
    *front derailleur/rear d: LX/SRAM X9
    *shifters: SRAM X9 Triggers
    *pedals: Shimano M540
    *stem: Easton EA50 100mm
    *handlebar: Easton EA50 low-rise
    *seatpost: Thomson Elite
    *saddle: Selle SLR Gel Flow
    *headset: FSA
    *grips: Lizard Skins Northshore
    *tires (front/rear): Intense System 4 2.25
    *front wheel: DT Swiss EX 5.1, King ISO hub, 20 mm TA
    *rear wheel: DT Swiss EX 5.1, King ISO hub, QR
    *weight: around 15kg
    More pictures here.
    How many lbs spring of DHX coil and sag ? plz
  10. #110
    rain rain go away...
    Reputation: peachy-B's Avatar
    funky cable routing.
  11. #111
    My brake cable chewed up frame
    I was wondering what people were doing with this. I see people have been putting some kind of protection there. Here is the damage to mine. Perhaps I will try that cable routing.
  12. #112
    polyurethane clear tape. similar to ones used in the hood of a car to protect it from stones. 3M makes a very good one. acrylic adhesive. i dnt have anything like that... wouldn't want to.
    like this:
    http://www.aircraftspruce.com/catalog/cspages/8672.php
  13. #113
    011100000110111101101111
    Reputation: unfluid one's Avatar
    Aug 2005
    Or you can reroute your cables entirely. .. Nomad/Socom style, or
    just loop below the lower pivot bearing of the upper link.
  14. #114
    3M tape
    3M also make the same stuff in sheets that you can custom cut. i found some at a window tinting store. great stuff. and comes off with very little effort.
  15. #115
    double post
    if you have to get off your bike, you're doing it wrong.
  16. #116
    Frame: hot rod orange
    *Rider weight: 180
    *Rider height: 6' 3”
    *suspension: van 36rc2 / dhx air 5.0
    *brakes: avid juicy 7
    *cranks: saint
    *front derailleur: deore
    *rear d: sram x-9
    *shifters: sram x-9
    *pedals: shimano m647
    *stem: raceface diabolus
    *handlebar: raceface daibolus
    *seatpost: raceface diabolus
    *saddle: wtb shadow v slt
    *headset: chris king
    *grips: odi rogue lock-ons
    *tires (front/rear):2.35 kenda small block 8
    *front wheel: azonic outlaw
    *rear wheel: azonic outlaw
    *weight: 36.5 lbs
  17. #117
    MOBtown
    Reputation: PALMEJ1's Avatar
    I will post a parts spec once the build is complete. I have a 2007 Marzocchi 66SL ATA, Easton Havoc AM Wheelset, Shimano XT M760 Crankset, and full XO group (rear dιrailleur, shifter, cassette, and chain) Should be around 32lbs when finished. Could,nt be happier Two thumbs WAY up!!!
  18. #118
    Reputation: Intenseman's Avatar
    Mine
    I will change Decals very soon (for my VPX too)
    'Tentense...or Intenseman
  19. #119
    Reputation: Hairylegzz's Avatar
    Mar 2006
    Let the fun begin
    Here's my newbie-
  20. #120
    Nov 2006
    Finally, I managed to build my 6.6, one for all bike. See how it goes.
    More details here.
    Full filled with 6.6 then migrating to Slope Style for more. "Intense Slope Style Central"
  21. #121
    Wow
    I love that look. That is sweeeet. I also have a gun metal grey one. Mines a large. The smalls look so sick. The small 5.5 is also sweet. They look so fast. What does that set up weigh?
  22. #122
    Nov 2006
    Quote Originally Posted by Ridnw/bear
    Thank you, thank you. For some frames, small don't look that good but I think I agree with you that small 6.6 looks awesome. I don't have a scale now, so don't know how much this 6.6 weighs, but 5.5 with Nixon was strong to take jumps and light, about 14.5 kgs (though for xc riders 14.5 is not light but it is light to me considering the weight of the tires, 1.2kgs each).
  23. #123
    Reputation: E2@CC's Avatar
    Dec 2005
    OneBikeGuy
    That build looks great, I love not seeing a ton of spacers below the stem.........low like it should be!
  24. #124
    Nov 2006
    Thanks E2, but I just found out the headtube was crack!!!
    I'm taking it back to the LBS, but I used FSA headset like Intense told me....
    Mine is one of the earlier one with the 2005 FOX DHX Air. I wonder if earlier frame had some kind of mis-measurement of something, instead of blaming for the other incidents with Cane Creek haedsets.
  25. #125
    Dec 2005
    Quote Originally Posted by OneBikeGuy
    Who knows who's fault it really was, but i'm sure Intense will take care of you. Make sure your local shop greases the headtube before installing the cups(some shops don't). We've sold quite a few of these frames with Cane Creek H/S and haven't found them to be a problem, we've also done a number of them with FSA, and no issues there either. Ride On-E2
  26. #126
    Nov 2006
    The cup was greased really well.
    I just go back to 5.5 with Cane Creek S3 headset for now. I've done enough playing around with 5.5 but 5.5 was good after I fixed the rear triangle problem, then problem with King headset (replaced to S3) and it was riding really great.
  27. #127
    May as well add to the family of 6.6s here :)
    Have had mine since last Feb and have loved it every chance I get!
    Tossing up the year of the parts as some people have asked me what year certain things were...
    specs:
    frame: 06 small baby blue
    fork: 06 marz 66rc2x
    shock: 06 canecreek double barrel
    brakes: 07 avid juicy 5s with red dangerboy lever replacement
    headset: 06 canecreek doubleXc
    stem: 06 easton vice
    bars: 05: fsa dh400
    grips: 06 odi intense lockons
    post: 06 easton ec90 zero
    saddle: 06 wtb lazer v team
    der/shifter: 06 sram x9 w/trigger shifter
    crankset: 170 shim saint double ring (using a single ring with the envy double E chain device and a red e13 supercharger)
    peds: 06 shim 647s
    cass: 07 sram 990
    chain: 07 sram 990
    rubber: maxxis minion dh f/r 2.5
    front wheel: 26/36 mag30 laced to candy red hadley
    rear wheel: 26/36 mag 30 laced to candy red ti 108 hadley
    To be changed in the very near future:
    -have a new wheelset being built up right now: the hadleys listed above are getting laced into mav823s and will have michie dh16 (front) and dh24 (rear) in 2.2.
    -getting a ti coil to replace the stock steel for my double barrel
    -maybe giving the 6.6 a fresh coat of paint this winter...not sure yet.
    Now for the pics...
    yes, I like the candy red/baby blue colour combo :)
    enjoy!
  28. #128
    Reputation: misctwo's Avatar
    More details here.
    killer build! what stem is that, dangerboy? sr-71?
  29. #129
    Nov 2006
    You guessed it right. SR71 to keep the handlebar height down.
    I even have a 31.8 diameter version of SR71 and it looks even more matched with the OnePointFive fat headtube of 6.6, so I will find a matching handlebar (probably Syncros white FR bar), so I can change the stem to 31.8 version.
  30. #130
    Nov 2006
    <made mistake on the reply button, so I will post it here again.>
    Now, Brendan emailed me right away and offered me to resolve the issue.
    No questions asked.
    I had never received this kind of prompt user support from any other bike manufacturers before. It makes me feel like I bought a Benz (sport type of course). I came across with people from component company's like Bob from manitou, Chris from Enduro and Brian from Therapy component are also should be noted that they provide superb services, but Kona, Iron Horse were so ignorant (although the distributor of Iron Horse in Japan is good).
  31. #131
    Reputation: freeryder's Avatar
    Wink here`s mine ....
    here s my 6.6.
    V2 COVERT on GTI MK5
  32. #132
    Nov 2006
    Mine's going to be like yours! White frame with white allmoutnain sl1.
  33. #133
    Nov 2006
    90% complete
    So I'm 90% through my winter project bike and thought it was time to post a picture. I really wanted to get a few shots of it before it gets ridden any more. It had it's maden voyage yesterday, a trail ride on Dec 31 in southern Ontario Canada isn't all that common. It almost took as long to clean it up as it did to ride it.
    Still needs a front derailleur. Seat post is off my DH bike so it will need to go back and be replaced with something lighter. I'll be changing out the pedals for clipless maybe CB single Ti with red springs. Lastly some red ano Dangerboy bar end plugs with the maple leaf etched in.
  34. #134
    Nov 2006
    My replacement frame became pearl white!
  35. #135
  36. #136
    Reputation: Justanuthabika's Avatar
    Back in Black!
    After riding my tracer for five years, I decided to take advantage of the trade in program and upgrade to a 6.6. As I expected the craftmanship and attention to detail are amazing on this frame. I almost want to hang it on the wall in my living room! It truly is a work of art.
    This is my first attempt to post a picture, hope it works.
  37. #137
    Mar 2006
    Large, works finish
  38. #138
    i have got a DHX air 5.0 eye to eye 8.5"
    is that suitable for 6.6 ?
    thx
  39. #139
    Reputation: Ronnie's Avatar
    Quote Originally Posted by west767
    thx
    The speced. shock size is 7.88" X 2.25"
    Ronnie.
    The trouble with having an open mind is that people will insist on trying to put things in it.
  40. #140
    Committed
    Reputation: 1soulrider's Avatar
    Nice red couch shot! Have you been hanging out in the Turner forum?
    Quote Originally Posted by Justanuthabika
  41. #141
    Nope, I just thought the couch was a good metaphor for "plush".
  42. #142
    Nov 2006
    Here's the photo after little updates.
    Intense, the distributor and the bikeshop got together to take care of my frame replacement! It'll be taken care of officially next week.
  43. #143
    huh?? another frame replacement?? what the heck...
  44. #144
    Nov 2006
    no, no, this white one is going to be official replacement next week when they pay me back for the deposit. To get this white frame fast, I put down the whole amount for the frame.
  45. #145
    understood. looking good as always!
  46. #146
    Nov 2006
    Quote Originally Posted by misctwo
    Thanks, I hope you are going to have good one with 6.6, too.
    I have the Gamut bash but with XTR 2007, I had to shave it off otherwise the crank was hitting the inner edge of the bash. I'm asking E2 if I can get Syncros chrome polished bash 36/38t.
  47. #147
    Reputation: nmtim's Avatar
    Polished...More or Less
    Just finished polishing the frame... Too snowy to ride so I found something to keep me busy. I went to AutoZone and picked up some $5 Mothers aluminum polish and started rubbing. There are still a few "cloudy" spots on it but I don't think I can take anymore rubbing. The CNC'd parts came out with a mirror finish but the seat and chain stays are still a little grey. Now I'm deciding if I should spend $40 on new decals. What do you think, leave 'em off or buy new ones?
  48. #148
    Quote Originally Posted by nmtim
    Looks fantastic mate, a real beauty. I must look for some of that polish here in the UK or something similar. Splash out on the decals they'll be the finishing touch. Was that all done by hand or was there some machinery involved? Real cool either way!
  49. #149
    Quote Originally Posted by doogie
    Most of it was done by hand with the exception of a few stuborn spots and those hard to reach places and then I used a dremel with a polish bit. That polish works really well ... If I had to do it all over again I would have left the decals on and just been really cafeful around them.
  50. #150
    Reputation: Just J's Avatar
    Feb 2005
    Oooh I like that!
  51. #151
    Freeriding Feline
    Reputation: SuperKat's Avatar
    Mar 2005
    Nice. I would try to go for the decals. What are you leaning towards...keeping them off?
    "If you give up your dream, you die."
    Twitter - KIKat1029
  52. #152
    Quote Originally Posted by SuperKat
    I like the decals on but I don't really want to spend $40 for new ones... I might try and see if I could just get the one on the downtube but I think they come in full sets.
  53. #153
    Reputation: iRider's Avatar
    Sweeeet! Real 'works' finish! By leaving the decals and the head badge off you save like 10-15 grams!
  54. #154
    Aug 2005
    I would go with some custom decals.. just on the downtube.
    Maybe "Intense" in red with a white outline....
  55. #155
    Quote Originally Posted by unfluid one
    That would be sweet but I just bought some downtube decals from E2@CC. He had some 5.5 decals so they will be black with white outline. Thanks E2...
  56. #156
    The original "AS" of MTBR
    Reputation: AS.. the original's Avatar
    Shame
    Shame I have to let her go.
  57. #157
    Where do you get those????
  58. #158
    Aug 2005
    Quote Originally Posted by iRider
    ahah i didn't... i said i WOULD get them done if i were him.
    Does anyone know of any custom decal makers?
  59. #159
    Sorry, wishful thinking. I was looking around for those decals you are describing. They would be sweet.
  60. #160
    Nov 2006
    I made some of these by myself. The gold/black decals to match gold psylo race.
  61. #161
    Wow, looks awesome (as always). How did you make them?
  62. #162
    Nov 2006
    Remember our Dawg period ?
    I made the logo design with Adobe Illustrator, then print it out the black lines using epson printer with special gold paper made for inkjet, then my wife cut it around the logo by hand.
    Then apply the protective transparent sticker sheet over it.
  63. #163
    Dec 2005
    Obg
    Those stickers look pretty sweet, I had some Intense downtube decals done here locally and they are cut from Green vinyl they look good, but not as flashy as yours....but they still add a bit of "one off" feel to the bike. I'll take some pictures of it and post soon.
  64. #164
    Nov 2006
    The wildcat sticker was little too flashy but I did that to kind of smudge the standing out gold Psylo Race. Now, with my Intense 6.6 white frame the decal (grey) is so perfectly matched with other things like AMSL1 has carbon and grey logo on white base, my crossmax sx rim, spokes and hbus are grey. So, for now, stock decals are perfect and I only added "Enduro" sticker to show my respect to Chris' business. I would stick CC, too though.
  65. #165
    6point6, not to be confused with IH 6point...
  66. #166
    W/ decals
    Yup, it looks better with the decals on...
    Frame: Works Polished
    *suspension: Marzo Z1SL / dhx air 5.0
    *brakes: Hayes Mags
    *cranks: truvativ stylos AM
    *front derailleur: XT
    *rear d: sram x-9 med cage
    *shifters: sram x-7
    *pedals: shimano
    *stem: Thomson
    *handlebar: answer carbon
    *seatpost: Thomson
    *saddle: wtb
    *headset: FSA 1.5
    *grips: cheapos
    *tires (front/rear):2.35 kenda nevegals
    *front wheel: DT swiss w/ hadley
    *rear wheel: DT swiss w/ hadley 10mm
    *weight: 31 lbs
  67. #167
    Nov 2006
    yep, it does look awesome.
  68. #168
    Looks good!
    From what I can tell from the pic you have darker spots around the welds. Did you tried to get rid of those?
  69. #169
    *headset: FSA 1.5
    which model plz ?
  70. #170
    Nov 2006
    Quote Originally Posted by lolo
    which model plz ?
    That should be FSA Orbit Extreme 1.5R, I think.
  71. #171
    Not it isn't possible, looks at well...
    I think it is the model : FSA Orbit Z 1.5R Internal Reducer 1-1/8 1.5
    It is not too small for this frame on the internal height level ?
  72. #172
    Nov 2006
    Daugh! I was looking at the wrong photo. I think I should stop posting.
    I tried Cane Creek XC Flush and for my small frame size, the shoulder of my fork was hitting. But I would use this on the top cup to reduce the stack height. Ringht now I'm using flush on the top and regular XC on the bottom.
  73. #173
    Looks good!
    I could have polished them out a little better with the dremel but my patience was wearing thin.
  74. #174
    which model plz ?
    Orbit Z 1.5R
  75. #175
    It looks very nice! I'd be interested to know if it stays shiny or if the aluminum oxidises and becomes dull again. Please let us know.
    Ronnie.
  76. #176
    NICE, reminds me of my beer stein from Williamsburg, VA!
  77. #177
    suspension cowboy
    Feb 2007
    after a lot of reading, now my first post ...
    I want to introduce you my Intense 6.6
    Partlist:
    Intense 6.6 "L" - Works finish
    Fox DHX Air
    Marzzocchi 66 RC2 ETA
    Saint Cranks
    Rohloff Speedhub 500/14
    Magura Gustav M Brakes
    CrankBrothers Mallet C
    Greetings from Switzerland!
    Ride on!
  78. #178
    I have one question :
    Intense 6.6 use Fox DHX Air with 2" (50mm) or 2.25"(57mm) travel shock ?
    Eric
    (I'm interesting to change mine for a Rock SZhox Pearl 3.3 (2" travel)...because my Post Office lost my DHX Air last week )
  79. #179
    *brakes: Hayes Mags
    *shifters: sram x-7
    *pedals: shimano
    *stem: Thomson
    *seatpost: Thomson
    *saddle: wtb
    *headset: FSA 1.5
    *grips: cheapos
    *weight: 31 lbs
    Fantastic mate! Great bike with an awesome finish! The hard work paid off.
    Enjoy and hammer the singletrack
  80. #180
    Isn't it funny, the aluminum around the welds looks darker even after the surface is pretty smooth? They must introduce quite a bit oxygen during welding.
    BTW: You can protect the finish with Neverdull or this wax some guys use on their car rims.
  81. #181
    Quote Originally Posted by lion-of-the-temple
    Partlist:
    Fox DHX Air
    Saint Cranks
    Ride on!
    Nice setup. Please let us know how the VPP suspension reacts to the torque that the Rohloff speedbone introduces into the swingarm.
  82. #182
    suspension cowboy
    Feb 2007
    There are no negative effects provoked by the rohloff.
    The reaction of the suspension is the same as with a derailleur. I could ride both setups (rohloff and derailleur) and I felt no difference.
    Ride on!
  83. #183
    Ride on!
    6.6!
    I just finished building and tuning my new pearl white 6.6 and here are the specs:
    Frame: 07 Large Pearl White 6.6
    Rear Shock: Manitou Evolver ISX-6
    Fork: Manitou Travis Single 180 1.5
    Headset: FSA Orbit Extreme 1.5 w/ Manitou Travis Headlock
    Stem: Gravity Light 60mm, 6 degree, 1.5
    H-Bar: Truvativ Hussefelt Platinum
    Bar Ends: Dangerboy Red Ano. Leaf
    Grips: ODI Lock-on
    Seatpost: FSA FD-200
    Saddle: WTB
    Crankset: Truvativ Hollzfeller
    Shifters: LX
    R.D: XT
    F.D: XT
    Cassette: XT
    Chain: PC-99
    Brakes: Hayes HFX-9 8" F and R
    F. Wheel: D321 w/Marz. 20
    R. Wheel: Mammoth w/Real Hub
    F. Tire: Maxxis Minion 2.5
    R. Tire: Maxxis Hansventure 2.35
    Pedals: Sun Zuzu
    Hopefully, I'll get to post some ride pics soon.
  85. #185
    Nov 2006
    With Travis 180mm, looks cool. how is the bar height?
    Did the headlock come with the fork?
  86. #186
    6.6
    Before I built the bike I was worried that the Travis would slack the bike out too much but I'm actually really happy with it. It feels perfectly balanced. The Travis is 572mm A-C and it fits perfectly with this frame and my riding style. Since this frame has such a long seattube I would actually prefer a little taller fork (but I doubt that happens). I measured the bottom bracket height at 14.25". I've only taken it out for about 3 hours and hit a mix of jumps and did some xc. Its totally awesome on singletrack - corners like a beast and climbs like a goat. On the freeride/jumps/technical it feels pretty good, I was impressed by the shock but the long seattube is going to take some getting used too. This shouldn't be a problem and should be relatively easy to get used too and also improve my riding style. I haven't ridden any pure downhill yet but will probably get to the mountains in the next few weeks.
    I bought the Headlock seperately.
  87. #187
    Reputation: DrEVS's Avatar
    Apr 2005
    My recently built 6.6...
  88. #188
    on a routine expedition
    Reputation: Marshall Willanholly's Avatar
    Here's a photo of cbharping racing her 6.6 at Fontana last weekend:
    photo by Drew Persson @ PhotoTurbo
  89. #189
    Feb 2007
    my new 6.6
    here is the build
    FORKS - Fox Talas RC2
    HEADSET - Cane Creek
    STEM - Thomson X4 (0 rise 90mm) (black)
    GRIPS - Odi loc-on Ruffians
    BARS - Easton Monkeylight Carbon (xc mx)
    DISC BRAKE FRONT - Hope Moto V2 (vented)
    DISC BRAKE REAR - Hope Moto V2 (floating)
    SHIFTERS FRONT/REAR - SRAM XO
    CHAINSET - Extralite E-Bones W (22, 32, 44) (172.5) + bolts (red)
    FRONT DERAILLEUR - Shimano XTR
    PEDALS - Burgtec Penthouse (black)
    SEAT POST - Thomson Master (31.6 350mm) (black)
    SADDLE -Selle Italia SLR XC (gel flow)
    CHAIN - SRAM PC991 (hollow pin)
    REAR SHOCK - Fox DHX (air)
    REAR MECH - SRAM XO (medium)
    REAR CASSETTE - Shimano XTR (11-32)
    WHEEL SET - Chris King ISO, Mavic XM819, DT Swiss competition/ pro lock al
    any ques just ask
  90. #190
  91. #191
    Sweet! Where did you get those black/white/red decals from?
  92. #192
    keep it fresh and make it sticky!
  93. #193
    Intenseman Handmade
  94. #194
    Nov 2006
    New Photo with white saddle
  95. #195
    Dec 2004
    Very nice :-)
    And, as usual, beautifully photgraphed too!
  96. #196
    Nov 2006
    Hi robbie, thanks.
    It rides great even riding around town doing some moderate aggressive stuff.
  97. #197
    Stylour
    Reputation: TeeWorks's Avatar
    ...but aren't the discs a lil too small? Or do they fit for your usage... :-)
    @will 6.6: pornicious setup will!! i only would replace the 3rd chainring with a bash
    Hey guys, i'm new to this forum! And i am a fresh and proud new owner of a 6.6 now, finally!
    Sadly still missing some parts to finish my baby, but here is a small gallery from what i got so far ( http://teeworks-net.de/intense/photogallery)
    one question i got: why some of the bikes have those "custom easton" stickers, and some do not - including mine?!? ...is this lazyness from the factory or what? *grr*
    seeya all! greets from munich, germany!
    Tee
  98. #198
    Nov 2006
    erased___________________________
  99. #199
    Quote Originally Posted by TeeWorks
    Tee
    that stealth is amazing! F-117 action! so, yes your bike is LESS stealth if it's got the custom easton sticker anyway....
  100. #200
    KMG
    KMG is offline
    Mar 2006
    Hey Lion, how does your 6.6 fare with the Gustav's? Have you found them to be overkill or are they ok. Presume you are using it for AM/FR use.
