5.5 EVP Tyre Clearance
Printable View
  • 12-05-2012
    JimboM
    Hi guys
    Getting the last few bits together for my build and now need to sort some rubber. Do I need to be aware of any tyre clearance issues on the 5.5 EVP or can I pretty much fit any size tyre.
    Was thinking of some Bontrager XR4 but apparently they come up huge!!
    Jim
  • 12-05-2012
    iRider
    Depends on if you have an older style swingarm or the latest version. Later versions have more tire clearance and fit a 2.35 Nevegal mounted on a Mavic 819 with some room to spare.
  • 12-05-2012
    JimboM
    Not sure of the catual age of the frame but it's going to be the older type swing arm, is this likely to restrict me to something like a 2.2
  • 12-30-2012
    masterlucasdude
    You can tell by the serial # on the under part of the BB. I think you will be ok if it's '06 or later. The decals are also a big giveaway. Unless they have been changed or stripped.
    Post some pics for everyone to help.
  • 01-22-2013
    Rob L
    I built up a 2004 5.5 last weekend. My 2.35 Nevegal works fine with the older rear triangle.
