5.5 Chainline Question
I'll be installing a Race Face Deus XC crankset with outboard bearings
on my new 5.5 frame.
First time I've installed this type of bottom bracket.
Instructions suggest a variable quantity of spacers be installed depending on the
chainline.
Should I use the 48, 49 or 50mm chainline spacer recommendation?
Thanks,
John
5.5 Chainline
You are going to want to use the 50mm chainline. That should work well.
Wow,
Info right from the factory guys who really know there stuff!
This kind of service along with your awesome frame designs are the reason I've been riding Intense frames for the past 8 years.
Thank you very much.
- You may not post replies
- You may not edit your posts
Forum Rules
