    275 Converted Carbine vs. Carbine 275
    I stopped by an Intense demo this weekend and rode a Carbine with the 275 dropouts. I asked if there were any differences between a converted Carbine 26 and the Carbine 275 and the rep said that there were no differences. This was surprising to me given that the Carbine 275 web page says:
    When we decided to venture forth into 650B territory, Steber quickly figured out that a simple dropout change could morph the incredibly popular Carbine into a carbon fiber 650B (or 27.5) frame.This is possible because of the” G1″ replaceable dropout system on all our frames , offers future compatibility and different axle choices.
    A few weeks later, new dropout in hand, samples were produced. Frames were dispersed for testing, refinements were made and the Carbine 275 was born. Much more than a conversion but now a dedicated 27.5 frame with proper travel , geometry and aggressive 27.5 trail geometry.
    This would tell me that there are likely differences between a converted 26er and the Carbine 275. It's tough to compare the geometry charts since the 26er doesn't list geometry with the 275 dropouts. The only apples to apples comparison I can see are the stack and reach numbers. The stack is the same but the Carbine 275 has a 0.25" shorter reach.
    Has anyone else attempted a comparison of the two? Can anyone else from Intense chime in?
    Dude, got any schwag?
    Reputation: TheSchwagman's Avatar
    The ONLY difference between a Carbine and Carbine 275 are the dropouts.
    Billy
    Speed is sweet, it's like an avenue to
    ... Shredtopia!
    BarBanger
    I bought a 26" 2013 Carbine frame and built it up as a 275. The only thing I had to do to the frame was add the 275 dropouts, as already mentioned. I also added the Fox 34 650 fork. But if you're just referring to the frame, the only diff is the dropouts between a "converted 26" and a 275, which are the exact same thing. Period. Are you referring to the Carbine SL maybe?
    Did you ever get a "good" answer to your question JTF? (Sorry, I am new to this topic, so will continue look for a good answer elsewhere...but I understand the question)
  1. Carbine FD?
    By mtnbikerx in forum Intense
    Last Post: 05-12-2013, 09:47 AM
  2. Replies: 13
    Last Post: 01-29-2013, 04:21 PM
  3. 650b Carbine Converted - Loaded Wheels
    By EK2K in forum Intense
    Last Post: 01-29-2013, 11:43 AM
  4. 275 vs Carbine
    By techfersure in forum Intense
    Last Post: 10-03-2012, 02:39 PM
  5. Carbine XL - Where is it at ?
    By Ob1Hoagie in forum Intense
    Last Post: 04-20-2012, 08:15 PM
