Page 11 of 14 FirstFirst ... 7 8 9 10 11 12 13 14 LastLast
Results 251 to 275 of 342
  1. #251
    May 2005
    Forget the Kings
    Industry Nine has the hub for you and available now
    Industry Nine SRAM XX1 Hub and XC29 Carbon Wheels | Mountain Bike Review
    2013 Banshee Spitfire V2 650b
  2. #252
    Quote Originally Posted by skidad View Post
    Forget the Kings
    Very sweet!! I guess that solves that problem!
  3. #253
    ride
    Reputation: ignazjr's Avatar
    Quote Originally Posted by Salespunk View Post
    I will second the love for the XTR Trail brakes. Rode Formula The Ones for years and switched over a few months ago. It was a significant upgrade.
    I'll say up front that I'm completely biased - I have Formulas on every bike I own. One of the biggest problems I have with Shimano brakes is that they are not repairable or rebuildable. Sticky piston that you can't fix? New caliper. Problem with the MC? New lever assy. I especially like the fact that if I have an issue with my Formulas, I can completely rebuild the brake with small parts that are readily available. I've ridden about every brake out there - Formula The Ones are still my favorite.
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
  4. #254
    May 2005
    Quote Originally Posted by gcohen View Post
    Elegant, color choices, flange choices, US made, and 120 POI goodness
  5. #255
    Feb 2010
    OK so I spent the afternoon at the LBS discussing the build. Need some input. We are leaning towards XX1. The original idea was Enve/Kings but as of now there isn't an XX1/king hub. We are going to contact CK and see if they are coming out with a compatible freehub in time. Otherwise I need to go DT 240's. Next dilemma is the brakes. My current bike has Magura MT6's, and I've ridden Magura for the past 6 or 7 years. I love Magura's, but have definitely had some headaches with the MT series this summer. When working properly the performance is fantastic, but I've had to bleed them quite often. I suggested the new XTR brakes. LBS says MT8's. We are putting a Fox 34 float, reverb stealth, carbon bars, ck headset on to complete the build.
    I'm looking for thoughts on the hub situation and the brakes.
    Thanks in advance for your input
    How are you doing a Reverb Stealth? Is your shop modifying the frame? I ask because I didn't think the Carbine was setup for stealth cable routing, only the Tracer275.
  6. #256
    Quote Originally Posted by chargerfan View Post
    I thought the same thing, but my LBS seems to think it has the routing. I've yet to see a picture of a Carbine with stealth routing so if the frame shows up without it I'll switch to the new KS Lev.
  7. #257
    Quote Originally Posted by ignazjr View Post
    That's an interesting point. I will have to take that into consideration.
  8. #258
    ride
    Carbine does not have stealth routing.
    Redstone Cyclery
    web - tweet - FB
    Lyons, CO
  9. #259
    KS Lev it is!!
  10. #260
    Reputation: JChasse's Avatar
    gcohen, your build is really similar to mine. Here's my thinking...
    I'm putting XX1 and a Fox 34 160mm fork on a Tracer 275. I was toying with the idea of I9 hubs because they're pretty blingy. But I ended up going with DT240s. They're admittedly not as sexy, but I've got 240s on 5 different bikes and I've never had a hub issue - they are pretty bombproof. And they're the lightest option i was considering.
    I'm using XTR Trail brakes because after wrestling with Formula R1s for 2 years, I was blown away by how much more I liked the XTRs. No ridiculous pad rub issues, they're dead silent (the Formulas made crazy noises from day 1 regardless of which pads I used), and the XTRs seem to have incredible modulation compared to my "on/off" experience with the Formulas.
    I guess the rebuild concern has merit, but I've never had to rebuild a set of hydraulic disc brakes. I'll take better performance over the ability to rebuild any day, since the annoyances I had with Formulas actually affected my enjoyment of riding the bike.
  11. #261
    JChasse. Enjoy your Tracer. The builds are similar. I'm pretty sure we are going with I9's. My LBS is big on high POE. The brakes are still undecided. I keep going back and forth between the MT8's and the XTR's. My frame and wheelset is a few weeks away, so I have a little time to make up my mind.
  12. #262
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    KS Lev it is!!
    GOOD choice! The LEV is the smoothest dropper ever I liked my '12 Reverb, but I LOVE my LEV
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
  13. #263
    It's official. Industry 9 hubs it is!!
    Here's how it's looking so far
    Carbine 27.5 Medium in naked carbon
    Fox 34 Float
    Enve AM/Industry 9 wheels
    Sram XX1
    Either Magura MT8 or Shimano XTR brakes - still can't decide
    KS Lev seatpost
    Easton EC70 bar
    Easton stem
    CK headset
  14. #264
    May 2005
    Sweet, its' gonna be a beauty and can't wait to see it.....and ride report of course.
  15. #265
    I'll post pics as parts come in and get built up.
    I've owned a few 5/6" travel 26" wheel over the years, and have ridden some Specialized and Cannondale fs 29ers this year, so I can offer a comparison to those once I throw a leg over the carbine.
  16. #266
    Fox 34 Float
    Sram XX1
    KS Lev seatpost
    Easton EC70 bar
    Easton stem
    CK headset
    WOW, bling bling. With XX1 also?! AND carbon wheelset. Would you like to adopt a son.
    We Ride In God's Country!
  17. #267
    74 & 29 pilot
    Oct 2010
    Fox 34 Float
    Sram XX1
    KS Lev seatpost
    Easton EC70 bar
    Easton stem
    CK headset
    REALLY That SWEET AZZ AM build and those narrow little 685mm XC bars I think you need to with the Havoc bars if your that into Easton
    MAN, that's going to be a light rig!
    MTBP
  18. #268
    Quote Originally Posted by MTB Pilot View Post
    LMAO!! I had wider bars on my 26" bike and caught trees a few too many times. I'm running the 685mm Easton on it now and it's much better for my trails. I loved the stability of that wide bar, but gettin thrown off the bike from clipping a tree sucks
  19. #269
    Reputation: johnny thunder's Avatar
    Bars
    If the sky is the limit with your build, then why not go with the Enve bars and cut them down if 700mm is too wide. Can't wait to see your pictures when it's complete.
  20. #270
    No particular reason. I have the Easton bar now and it is strong and light. Who knows, maybe when it comes time to put the stem and bars on things will change.
  21. #271
    May 2005
    Answer Pro Taper Carbon 720 is just right...for me anyway. Really nice bar.
    I tried some wider Spank Subrosa 747 bars and it was just to much between smacking trees and being uncomfortably wide. Cut em to 720 and all good
  22. #272
    Meanwhile, back to the 275 wheel size, has anybody got there G1 275 syntec rear dropout kits yet? Sam at Intense told me it would be the second week in November. Anybody?
  23. #273
    74 & 29 pilot
    Oct 2010
    Quote Originally Posted by doralswheels View Post
    I got my kit from the company I bought my frame from; That was at least 6 weeks ago.
    MTBP
  24. #274
    I just changed my order from a Tracer 275 to the Carbine 275. They had one Flow Green small in stock and they're shipping it this week. Here's my build (everything coming from my current Spitfire except fork/wheels/tires):
    Sm Carbine 275
    XFusion Slant Fork 150mm (not avail until late Feb, going to go nuts waiting)
    XT 2x10 38-26
    XT Clutch RD
    XT Shifters 9 speed
    XTR 11-32 9spd cassette
    Easton Haven Carbon bars
    Hope Pro 2 Hubs
    Chinese Carbon 650b rims
    CK ZS44 Upper/EC49 Lower
    Easton Haven stem
    Thomson Elite Post (with shim until Thomson dropper post is released)
    WTB Rocket V Ti saddle
    XTR 988 brakes with Avid 160mm rotors
    Straitline AMP Pedals
    tires (RR, NN, WTB Wolverine???)
    Should come in just over 25 lbs before the dropper and closer to 26 lbs with the dropper post.
  25. #275
    Just received an awesome text from the LBS... "Frame Shipped"
