Results 1 to 6 of 6
    Lord of the Chain Rings
    Reputation: orastreet's Avatar
    2010 Uzzi with XTR 175mm M985 cranks
    Original setup - MRP Chainguide with 175 XTR M970 cranks. Then I upgraded to Saint, but these are 165 mm for more clearance. All that worked fine.
    Since then, I cracked the rear triangle which was replaced by Intense. It's been working with the Saint cranks, though it was hitting rubbing the chainstay, but barely. Sitting around I have an M985 crankset that I bought a Wolftooth no drop ring for so I could lose the chainguide. I tried to put the XTR M985 cranks on last night and the are arms are hitting the chain stays. By the time I get it wide enough with spacers, I can't get the other side on.
    I have to put 3 spacers on the drive side to get it to clear. I have to put one on the non-drive side. Any idea what is wrong here?
    Uzzi
    Pictures say a 1000 words..this is what I'm trying to figure out.
    Why are these crank arms hitting the chain stay?
    Non Drive side -
    2 Spacers on Drive side, 1 on non-drive side. To make this work, I need 3 on the drive side, but now the spindle isn't long enough. What the heck is going on?
    Any ideas?
    Uzzi
    dab
    dab is offline
    Smile UZZI Troubles
    Wow, what is going on there. I have a 2012 model and have basically the same setup, I am using a Shimano XTR BB 1 spacer on the drive side and a M985 170mm crank with a RaceFace 30T narrow wide chain-ring. I use to have a M952 165mm crank-set and it also had enough clearance. I did notice that my rear has a indentation probably designed for crank clearance issue. Sorry not so much help, hope you get it worked out.
    I believe that the new style rear triangle has wider spaced c/stays to help with stiffness and strength. However, it has lead to some compatibility issues.
    Reputation: dynamicz's Avatar
    Had the same issue on my previous 2010 Uzzi. I had the 150mm rear space version and I was running Saint M815 - 68/73mm BB, 175mm length cranks and it was <1mm on the drive side and at times with some flex would make contact with the c.s. Non-drive was alil better at 2-3mm. I didn't want to mess up the c.s. on the drive side so I traded my Saints for the 83mm version and used the raceface bb conversion adapter. Had 5-6mm on each side and didn't have to worry anymore.
    Not sure if you have the 135 or 150 spacing but since I resolved my issue, may help you too.
    Thanks man! I see that with these cranks, I'm basically out of luck and there is no way to run them on this bike. I have Saint cranks, but they are 165mm - so I'm not stuck, very surprised a 68/73 mm BB won't work with these cranks. I understand it's not the BB shell that is the issue, but the chain stays. I can just put my Saint cranks back on and be happy.
    Uzzi
  1. 172.5mm vs 175mm cranks
    By Taz8 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-14-2013, 07:17 AM
  2. ss rings for m985 cranks
    By conrad in forum Singlespeed
    Last Post: 07-01-2012, 11:37 PM
  3. will a 24-38T combo work on xtr M985 cranks?
    By argibson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2012, 11:09 AM
  4. New El Guapo owner - 170mm or 175mm cranks?
    By Shatmepants in forum Titus
    Last Post: 11-09-2011, 04:20 PM
  5. Need Help. Trying 1x10 with XTR m985 Cranks
    By mucky in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-30-2011, 10:03 PM
