Page 1 of 7 12345 ... LastLast
Results 1 to 25 of 174
    Reputation: mr intense's Avatar
    2009 Uzzi vp sneek peek
    Sneek peek at 2009 Uzzi vp , changes still to be made as this is the 2nd proto but getting close. Travele adjust (like Tracer vp ) 6.75" or 7.25" 2nd gen VPP w/ new bearing zirk system, Iscg 05 integrated bb, 1.5 head tube . more specs to come.Leverage ratio in the 2.5 / 1 range , coil or air .
    Apr 2005
    Wow, very nice, sign me up please the color looks more like a candy apple red, silver base with red clearcoat.
    Reputation: nybike1971's Avatar
    Wow! It looks great, the red works is such an amazing paint job.
    Any guess about production frame weight?
    Reputation: twouareks's Avatar
    Gorgeous! I've been waiting for you to post this up too!! Thanks!!
    Knolliac
    Reputation: EastBay_Slim's Avatar
    WOW!
    Any more info on this Mr. Intense? Fork travel range? Shock length? Frame weight?
    wretch
    Reputation: Truckee Trash's Avatar
    I'm in.
    intense awesomeness. so after ordering my SS i'll need to get my hands on this uzzi and the tracer. i'll be broke dudes ...
    Dec 2005
    Nice, but replaceble dropouts should be a better choice for this frame...just my thought. It looks like 135 mm rear end, isnt' it? Maybe we'll see at Eurobike ?? :-)
    Ahhhh.... now that looks more like a replacement for the current 6.6. Like it a lot.
    One of those with a fox 40 set to 7 inch will do me....
    Meh
    the refurbished one
    Reputation: hball's Avatar
    the shock fit looks horrible. does not look like you can mount every shock you want to.
    Sokrates is dead, Galilei is dead, Newton is dead, Einstein is dead, Pantani is dead and i am feeling sick too.
    Apr 2005
    sweet.
    i trust that you'll make sure that someone using a Totem with a 1.5 steerer/headset, and tires that are large enough for loose conditions, will still have a bottom bracket height below 14 inches. as Intense knows, that was a common complaint w/ the previous uzzi vpx. not all of us want to run a zero stack reducer headset. skinny steerer tube, and smallish tires just to keep the BB reasonably low.
    Founder: Dirty3hirties
    Reputation: ddraewwg's Avatar
    Quote Originally Posted by hball
    True, but that looks to be a small....and it's just a proto. Other sizes would allow more options even in this model.
    May 2005
    Quote Originally Posted by ddraewwg
    Looks more like a medium to me.
    This is another test proto set up with a Travis 180 single 1.5 & remember as I said these are still protos and there are changes in process to address shock fitament, rate etc.
    The weld on drop out is set @ 135 but uses a chip that will allow standard, 12mm or Maxle configuration & it is a lighter setup as you can see we are trying both.
    Reputation: skatetokil's Avatar
    Quote Originally Posted by Fadl
    So here's a question for all you industry types: do manufacturers just design and proto a medium and then scale up and down for small and large? I've always felt like medium bikes rode better even though I should be on a large at 6'3. Might just be a preference for small bikes, but it seems like lots of rigs just look out of proportion in other sizes. I imagine that just adding or removing some tube here or there would totally change the weight balance and feel of the bike.
    lots of maggs here now....
    that is pretty much the way I do it , start @ the medium size for several reasons, it will fit more people for test riding & I always scale up and down from there as the medium is always what I consider ideal numbers ( wheelbase , height ,etc.) I have always ridden a medium size frame even though most people would put me on a large cause I like the fell of this relationship the best.
    Front Range, Colorado
    Oct 2000
    Quote Originally Posted by mr intense
    So if you ride a medium how tall are you? I have always rode a large at 6' 0" but I have never tried a medium so I can't compare.
    29'ers should come with a warning label affixed to the toptube.
    WARNING: Objects may be further than they appear.
    Stray Bullet
    Reputation: Nagaredama's Avatar
    Please tell me the new VPX will be available in XL.
    Stray Bullet
    Any more geo numbers?
    HA?
    BBH?
    Reputation: sanjosedre's Avatar
    I like it but with my SS I find it hard to justify a new frame for .75" increase in travel.
    just brilliant!
    the dropout thing sounds like a great way to make as many people as possible happy.
    Dec 2005
    Tracer = 5.5 to 6.0 travel
    Uzzi = 6.75 to 7.25 travel
    Bye Bye 6.6
    Reputation: iRider's Avatar
    Quote Originally Posted by frorider
    Other dropouts would solve that problem EASY, but I am still waiting....
    The new Uzzi LOOKS good!
    Although from experience I am fearing that the monocoque is not as crashworthy as the tube'd frame on the old one. And again this low-low-low link on the new VPP......
Hot Deals
Contests
Latest Mountain Bike Articles
