Results 1 to 2 of 2
    Reputation: dreicha's Avatar
    Aug 2005
    2 different coil springs for tracer vp?!
    Do I have to use two different springs for a tracer when i change travel from 5.5 to 6" ?
    RIDER WEIGHT ~190 lbs
    sag - 27%
    5.5" - 450
    6" - 500
    Reputation: boogenman's Avatar
    the leverage ratio changes a bit between the settings, so yes two springs would be best. You can also choose a spring for the setting you are going to use more often and then use the pre-load to get it close to the other spring rate.
