Results 1 to 14 of 14
    What lubricant in Boise
    Hey guys, I'm coming from North Idaho where all I used to use was a little triflow on the chain, and I was set. I've been living/riding in boise now for a couple of months, and my triflow solution is drying up and making my chain creak after just one or two rides. What do you guys use on your chain for mainly foothill riding?
    Sheepherder/Cat Herder Moderator
    Reputation: Visicypher's Avatar
    Rock n' Roll. The blue stuff. They are Boise based now. I still use it now, even though I live in CDA.
    ...building wherever they'll let me...
    mtnjam
    Reputation: ryman's Avatar
    +2 for blue Rock n' Roll.
    The DuMond Tech stuff, didn't like nearly as much, seemed to gunk up my chain more than even White Lightning.
    Reputation: flipnidaho's Avatar
    The best I've ever used. After the initial couple of applications, i apply maybe once every 3 weeks if riding daily. The chain sets up dry but totally quiet.
    Chain Wax - $6.95 : Maxima Racing USA, - Overkill
    Dumonde thinned down a bit with mineral spirits
    also like Pro Gold M/C chain lube
    TRAIL KUBUKI CORNDOGGER
    Reputation: TwistedCrank's Avatar
    Juice from a jar I keep in the back room that has Einstein's brain in it.
    Nobody cares what kind of bike you ride.
    Reputation: ianjt's Avatar
    +3 blue Rock N' Roll. Keeps things off and out of the chain, as it should. Everything else created more problems than it solved.
    Look out!
    Reputation: mtnbkrid's Avatar
    +4 for blue Rock n Roll. Works great!
    Ride the bike.
    jalepenio jimenez
    Reputation: mudflap's Avatar
    I'm a chain lubber. I lub my chain and really hate to see it get dirty. all that squeaky black-board screechy gnashing of steel on steel from a dry chain can make a guy deaf, so when it gets so loud that it hurts my ears, I just whip out my lub applicator and squirt a little lub juice on that red hot drive chain and after the steam and the hissing has stopped, I get back on and yank those cranks hard...
    lub juice...cools down hot calipers, hotter discs and noisy drive trains
    White Clouds - Heart of Idaho
    Feb 2006
    5-20 synthetic oil and mineral spirits.
    +5 rock n' roll blue.
    Custom Wheelbuilder
    Reputation: Zen Cyclery's Avatar
    Another vote for the Dumonde tech lite. This time of year things can get pretty dusty in Boise, and the Dumonde tech is definitely good at shedding some of the more fine particulates. Don't use too much of it though, and make sure you wipe off your chain after applying.
    Check out www.zencyclery.com for fully customizable, handbuilt wheels.
    www.facebook.com/zencyclerywheels
    Rampart
    Aug 2010
    +6 Rock n Roll Blue.
    +7 rock n roll blue! I'm a little further south (Twin Falls) but trail conditions are very similar to foothills.
    Gears give me headaches
